K&N filter part number
Old Apr 21, 2012 | 10:12 PM
Robert Page's Avatar
Default K&N filter part number
Hi does anyone know the part number for a K&N air filter for a 2007 XK? All the car stores don,t list one and there is conflicting info on the web. If I can't get one in the US I have relatives coming over from the UK who could bring one. Also has anyone used ceramic brake pads on standard rotors to cut down on the dust thinking of replacing my Pads with EBC pads but don't want to change the rotors.
Old Apr 22, 2012 | 08:11 AM
CleverName's Avatar
I cleared this post due to incorrect information I provided.
K&N does not make a replacement engine filter for a base XK.
Vince
Last edited by CleverName; Dec 6, 2012 at 08:01 PM. Reason: correcting misinformation
Old Apr 22, 2012 | 01:08 PM
mosesbotbol's Avatar
I did on my VDP. Went with new OEM rotors and Akebono ceramic and it worked out well. Not as much inital grip as straight OEM, but go final braking and way less dust. I plan to change the pads on XK as soon. Still not sure as you are on which ones to buy. Akebono only makes a rear.
Old Apr 23, 2012 | 09:19 PM
Thanks guys I will try that part number. Will look at EBC red pads and see if I can get them brought over from the UK as they seem to be cheaper.
Old Sep 11, 2012 | 09:33 AM
Rey's Avatar
Rey
Beware. The K&N air filter 33-2190 does not fit the 2007 XK, or any 2007+ XK/XKR.
The 33-2190 fits the XK8; and K&N mistakenly lists this filter when you search for a 2007 XK filter. Seems that K&N thinks the 07 was designated as an XK8 and XK
Old Sep 11, 2012 | 10:04 AM
Akebono is supposed to have XK pads come early 2013
Old Sep 11, 2012 | 02:26 PM
CleverName's Avatar
I will see what i can find out about this.... I just email the k&n tech folks with your complaint to see what they say... I will also order one tonight (hoping yours was a mispackage product) and RMA it if i have to.
Vince
question: was the xk8 and the xk in production at the same tme for 2007? Or did the arrival of one terminate the other?(sorry, i have no idea if they came from the same plant.)
CONFIRMED: . . K&N DOES NOT make a filter for the 2007 -2009 series XK.
Old Sep 11, 2012 | 04:11 PM
Yep found out that that part number does not fit so have a 2190 sitting in my Garage. K&N do not do a filter for the XK.
Old Sep 11, 2012 | 05:21 PM
amcdonal86's Avatar
I have switched to ceramic brakes on other cars without any noticeable problems.
philwarner
Oct 4, 2024 01:37 PM
Doug
Feb 27, 2019 01:31 AM
Tar
Sep 6, 2015 11:24 AM
Busa R
Sep 3, 2015 05:01 PM
pnwrs2000
Sep 3, 2015 11:55 AM
