LCD screen locked again
Old Feb 10, 2012 | 08:03 PM
rscultho's Avatar
Tom - I can understand your frustration.
The battery minder staying on your car when it is sitting at home will keep your battery "topped off". When you drive it to work and let it sit there with the battery having started off at full capacity it may avoid the condition when you come back out to drive home.
Again I also recommend getting a high capacity AGM battery.
Originally Posted by TomServo
I bought and installed a new AGM battery after Jaguar claimed (one two occasions while I was under warranty) that my batteryand alternator "checked out" good. My 08 XK is a DD, it may sit for a day or two during bad weather.
My drive to work is just at 15 miles and takes between 30 and 40 minutes. I would think that would be sufficient to charge the battery after it's morning start up.
Most of my occurances happen while the car sits at work for 9 hours or so. I really don't have any ability to use a battery tender under these circumstances.
Very annoying on an car this expensive.
Tom
Old Oct 25, 2012 | 02:34 AM
dutch07xk's Avatar
I also have this problem, I wrote down when it happened, and it's like once per month, summer and winter. I'm a daily driver, so battery power should not be the problem. I can leave it for a week, start and it will work.
Every time this happened, I tried different things to make it work right away, and I've come up with this procedure:
After starting the car, and the screen is locked on the jaguar leaper, I turn it off, release the brake and push the start button again (so the engine doesn't start) I turn it off again, wait 5 seconds and start normal. 9 out of 10 times it will work after that.
Not much of a solution, but a workaround.
It's like a computer that locked on startup and needs a reboot.
Sad there seems to be no fix...
Old Oct 25, 2012 | 04:05 AM
steveinfrance's Avatar
This battery discharge is well known and a common cause of problems in these cars, all sorts of odd codes, TRAC and ABS errors being due to the car not going to sleep.
You do need to lock the car, and on European models give the lock button a second press so the car gives a 'squawk'.
Old Oct 25, 2012 | 06:25 PM
djgold's Avatar
I tried turning off the engine and setting off the alarm. Started it up and it works. Setting off the alarm resetted the system without waiting 30 minutes. Not fun but at least it works...
Old Nov 29, 2012 | 12:20 AM
u102768's Avatar
Grrrr, my 07 XKR joined the locked LCD screen club this morning, just a faint leaper on the screen all the way to work. A power off and on and lock unlock made no difference but it was OK again when I came home from work. I will try the alarm trick next time.
Old Nov 29, 2012 | 03:27 AM
dutch07xk's Avatar
It's an early sign of the battery going bad. I also had it until I changed the battery.
Old Nov 29, 2012 | 05:53 PM
muncher's Avatar
Mine was also giving me all sorts of wierd elec probs. Including locked home screen. I eventually worked out that my lead acid battery (wrong one) although only 3mths old was the culprit. I needed a AGM battery. Maintains a higher voltage than lead acid ones. All seems good now. I use my xkr every day so you would think that that was enough to keep the battery topped up. Doesn't seem the case. I also do a double push on the lock button on the remote. This puts the computers into sleep mode. I had my local battery guy hook up a voltage reader to the xkr without me locking the doors. Wow she sure likes the voltage. Even on single lock push she sucks up the voltage. So i always double push lock on remote. So far so good......Hope this helps.
Old Dec 1, 2012 | 01:30 PM
  #28
XKCoupe's Avatar
I bought my '07 XK new in April of '06. It was one of the first cars Hornberg Jag in Santa Monica had. I started having screen locking problems very soon after I bought the car. I lived in a condo so I always locked the car and it's a daily driiver. Each time I took the car in to check it out, they couldn't find anything wrong.
I moved to La Quinta recently and took the car to Desert European Motors in Rancho Miirage. David, the Jag service said there is a fix for the problem and which cost a little over $200.00 so I put it in. It's only been a couple of weeks but so far so good.
Old Dec 2, 2012 | 12:28 AM
Rey's Avatar
Rey
David in LaQuita: Please take a look at the work order for your Jag's upgrade. It should so describe the procedure done. Please quote the procedure to this forum as it will help others with the same problem when they try to explain the "fix" to a service advisor.
Old Dec 2, 2012 | 01:30 PM
  #30
XKCoupe's Avatar
Rey here is what the service order says, "S121 performed reprogramed HLDF. 843 CPJ, parts $217.50.
69672 Performed reprogramed HLDF display. Found needs software update, performed reprogramed HLDF disllay, tech bulletin JTB00149".
In retrospect, I hope they didn't just give me the 2011/2012 database update as I bought that about a year ago and it didn't help the frozen screen.
Old Dec 5, 2012 | 07:31 PM
  #31
Howell's Avatar
Default LCD Touch Screen Issues
My 2008XKR has issues at times, seems to be cold weather and or sitting for extended period, or maybe phase of moon, but no real pattern. One time, I drove directly to dealer with system locked. Of course after diving into unit, issue went away!
I suspect that the Jaguar tools available to dealers are very lacking in diagnostic features, low voltage and intermittent in the MOST system would to be almost not possible to trouble shoot. Jaguar needs a good on-board diag. tool to put in car and have it trap the logic when things go bad. Dealers can make brave attempts but one is lucky to trap and correct the problem.
They need some better code in the on board computer for this issue. Likely we will be reading about this problem for years.
Those of us that wrestle with this can only hope some clever Jaguar software person gets interested in this issue and gets funded to work on it.
Old Dec 5, 2012 | 07:36 PM
  #32
XKCoupe's Avatar
Howell, did my post above help? I had the repair done recently and it's too early to tell if it's really a fix.
Old Dec 6, 2012 | 04:21 AM
  #33
u102768's Avatar
I plugged my diagnostic reader in to the car and found a number of codes which are probably related to my screen freeze.
It looks like the BPM lost contact with a number of modules which I think are all connected via the MOST ring.
Old Dec 6, 2012 | 08:06 AM
  #34
djgold's Avatar
I went to the dealer and had a bunch of codes similar to yours pop up. The mechanic told me these cars get those codes and others when the battery gets low or is bad. Seems a bad battery affects a lot of things electronic...
Old Dec 17, 2012 | 08:13 PM
  #35
XKCoupe's Avatar
The fix that my dealer did didn't work. Screen locked up this morning.
Old Dec 24, 2012 | 11:40 PM
  #36
07XKJaguar's Avatar
Steveinfrance,
Thanks for that information. I had noticed that after mine sits for a few days that I get Cruise Control Not Available. But after driving, it doesn't come back. I had locked the car in the garage the other day without knowing it. I drove it to a funeral and I didn't have the problem anymore. I have noticed when going by the car that the screen wakes up even without my fob with me.
jluckcuck
Nov 6, 2015 07:49 AM
MattB731
Sep 30, 2015 10:37 AM
Bigvettefreak
Sep 28, 2015 03:03 AM
kevinl
Sep 24, 2015 08:25 PM
