Looking for stock or aftermarket cats
Old Sep 16, 2013 | 10:40 AM
TrexM3's Avatar
Default Looking for stock or aftermarket cats
Hey guys i have cat failure on my left side. Does anyone know of a aftermarket cat for our cars or have a stock one. Also if so what company do you recommend.
and yes im out of the 80k warranty
thanks in advance
Old Sep 23, 2013 | 11:15 AM
guy's Avatar
guy
I went with OEM... the biggest concern for me is what caused the blockage? A failed coil?
Old Sep 23, 2013 | 12:11 PM
R_Rated's Avatar
Magnaflow Performance Polished High-Flow Catalytic Converters - JEGS
Magnaflow is kind of the standard. Anything "better" is going to be niche and significantly more money.
Old Sep 26, 2013 | 08:02 AM
TrexM3's Avatar
replaced all the coil already , now just a failing cat
i was even considering running straight pipe, have you ever heard of anyone doing that not sure how well the temp would be reglsted with the 02 before and after the existing cat , do you have a model number for which magnaflow cat ? thanks for the help
Old Sep 26, 2013 | 09:59 AM
R_Rated's Avatar
The 02 sensor after the Cat would be eliminated or a dummy plug put in to keep the CEL light off. You WILL smell gas if you remove the Cats... I did this in my last car which was far more sports car oriented than the GT/luxury Jag.
I don't have a model number... but high flow cats will make a bigger difference to performance than an exhaust since they will by far free up more airflow. In the car industry it's taboo; and even illegal in some states, to modify working cats.
Old Sep 26, 2013 | 12:29 PM
R_Rated's Avatar
Also, may want to check the bearing on your catalytic converter and muffler... just sayin'.
Attached Thumbnails Looking for stock or aftermarket cats-539794_4896805509469_823849019_n.jpg
Old Nov 17, 2013 | 09:56 PM
TrexM3's Avatar
Thread update: gutting the cats this weekend and waiting on a new 02 sensor for before the cat . I'll post results .. Also to add I already have aftermarket mufflers and deleted the stock
Old Nov 18, 2013 | 07:47 AM
R_Rated's Avatar
Was it a muffler bearing?
Poet
Feb 7, 2025 02:18 PM
BlakeConverse
Sep 28, 2015 02:22 PM
SoCalJagS
Sep 27, 2015 09:20 AM
Zarro
Sep 24, 2015 08:34 PM
hoodun
Sep 23, 2015 12:17 PM
