Louvers Removal?
Old Mar 11, 2009 | 09:52 AM
GhostriderXKR08's Avatar
Default Louvers Removal?
Just want to see how to remove the side louvers? Do I just use a flathead screwdriver to pry it off? Any info would be greatly appreciated.
Thanks!
Old Mar 11, 2009 | 11:25 AM
jag_genius's Avatar
Depends if your gonna keep the ones that you pull off . You can pull them off . The tabs will break . And be useless. If your pulling the aluminum louvers off then id take the wheel arch down and push from the inside .
Old Mar 11, 2009 | 01:52 PM
Thanks. I'm pulling the plastic Grey louvers to replace them.
Old Mar 13, 2009 | 02:28 PM
gdrag's Avatar
If you go to the manual section listed at the top of this forum and then go to the new XK manuals and then to Accessory Fitting Instructions there is a document for installing the louvres...it even has pictures :-) gotta love those Brits...
Old Mar 13, 2009 | 02:44 PM
Sweet. Thanks!
Old Mar 14, 2009 | 09:21 PM
Thanks again guys for the info. I was able to remove the louvers today by working my way carefully from top down with a flathead screwdriver. When the tabs break it sounds worse then it really is. The chrome louvers are in and was a snap to install and I like the new look. If anyone is replacing the louvers, remember to remove the side marker housing by pushing the tab in the back and pushing it out.
Old Mar 15, 2009 | 02:08 PM
jag_genius's Avatar
Did you install the aluminum ones?
Old Mar 15, 2009 | 06:59 PM
My dealer advised I can't get the aluminum ones unless I have a Portfolio VIN Number. Therefore I had to go with aftermarket.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
mrsimpson
Sep 15, 2015 01:10 PM
SeanU
Sep 14, 2015 04:31 PM
doctordeuce
Sep 12, 2015 08:30 AM
