Mirror dipping in the wrong direction
Old Nov 3, 2020 | 04:49 PM
mhminnich's Avatar
Default Mirror dipping in the wrong direction
My RH rear view mirror is automatically dipping UP when I reverse. That seems rather contrary to what it should be doing. Suggestions?
Old Nov 3, 2020 | 05:27 PM
JackJohn's Avatar
Mine dips down but won't recover when I move the shifter to "D". Now that it is cooler in the garage I'll pull them off and see if a good cleaning and lube will help.
Old Nov 3, 2020 | 05:29 PM
Sean W's Avatar
Try putting the car in reverse, then while in reverse, adjust the mirror down. Then put back in drive. test again. Assuming you tried this?
Old Nov 3, 2020 | 05:46 PM
mhminnich's Avatar
I tried adjusting when in reverse but could not cause the mirror to move.
Old Nov 3, 2020 | 06:13 PM
mhminnich's Avatar
I went back out to try it again and found that I needed to hold the right mirror button down while adjusting it in reverse. Problem solved!
Old Nov 3, 2020 | 08:05 PM
guy's Avatar
guy
That happened to me once. Reset the electrical system (yes, with a new battery) and all was fixed.
Old Nov 3, 2020 | 09:01 PM
Aarcuda's Avatar
You got your mirrors installed upside down. switch em from door-to-door and try it
Old Nov 4, 2020 | 12:08 AM
kj07xk's Avatar
Naw, his car was meant to be used in the Southern hemisphere.
Old Nov 4, 2020 | 05:51 AM
Bill Mack's Avatar
JackJohn, same problem here. Let us/me know what you find. Thanks.
mhminnich
Nov 3, 2020 04:47 PM
qwakwak
Aug 7, 2020 06:18 PM
NikolaiDiqnov
Dec 15, 2014 02:58 PM
raschwar
Jul 14, 2012 08:40 PM
davies
May 19, 2011 09:06 AM
