Are my engine mounts worn?
Old Nov 15, 2025 | 01:33 PM
Street cat's Avatar
Default Are my engine mounts worn?
Old Nov 15, 2025 | 02:45 PM
Circumnavigator's Avatar
Originally Posted by Street cat
Mine are confirmed worn (08 XKR) and the engine doesn’t do that.
By worn, there are clear signs of the hydraulic fluid leaking.
Seems more than just worn.
Old Nov 15, 2025 | 02:51 PM
Street cat's Avatar
thanks. So no movement at all on your engine when revving to ~4k?
Old Nov 15, 2025 | 03:19 PM
McJag222's Avatar
Doesn't look excessive to me - the mounts are "designed" that way otherwise they may as well be cast iron - that'll keep the engine still.
Old Nov 15, 2025 | 03:20 PM
Don’t think so.
Not a fan of revving not under load, but I’ll go check and video it. BRB.
Was this at temp?
I knew mine were going because every time I start it cold, when it does the drop from ~1200rpms to ~900 the car does a brief shimmy shake. Does it again when warmed up and drops to the normal 600rpm idle.
Had shop lift it and sure enough, signs of hydraulic leakage on and under the mounts.
Update: It moved a tiny bit the first time before video. Barely noticeable. Not after.
Old Nov 15, 2025 | 03:28 PM
Street cat's Avatar
Don’t think so.
Was this at temp?
yes this was after a 20 minute drive and operating temp
dont know about the shimmy but the interior trim sometimes vibrates at idle when cold
also have a strange vibration / drone coming from engine at exactly 2900-3000k rpm - in every gear and even in neutral
Old Nov 15, 2025 | 03:30 PM
Street cat's Avatar
yes I thought this was maybe slightly worn but not crazy
the hellcat motors seem to move a lot when revved
can’t find a ton of examples of jags revving
Old Nov 15, 2025 | 03:38 PM
@Street cat
If you decide you need new ones, I got both for $180 including the trans mount. Aftermarket of course.
Site called IB Spot.
The ouch is install. Both my Indies want $800.
A third I called wants $960.
After digging through the forums, these XF are an exact match. Haha I hope.
Old Nov 15, 2025 | 05:37 PM
Sean W's Avatar
I check via power braking (or at least start there). If it lifts while power braking, in drive and reverse, then I would move on to checking with a pry bar. If you don't know what you're doing, take it to the shop to power brake test it. I'm guessing there are videos on power braking.
Old Nov 16, 2025 | 08:01 AM
sony2000's Avatar
When changing the alternator, an engine mount has to be moved. Maybe a good time to change the mount!
Old Nov 16, 2025 | 11:02 AM
HealeyJag's Avatar
Default Ok
That's what I mentioned earlier but there was some disagreement..
Had mined changed with the alternator
Old Nov 16, 2025 | 11:32 AM
Both mounts? I know the driver’s side also requires dropping the steering rack. No clue if that is a part of replacing an alternator.
When my guy priced out replacing my mounts, that was a chunk of the $800 cost.
Old Nov 16, 2025 | 11:54 AM
HealeyJag's Avatar
Default 2
2 mounts were replaced...are there 4?
Very little labor costs since they were there..
Had all pulleys replaced and belts too...
Old Nov 16, 2025 | 01:15 PM
No no, two motor mounts and 1 trans mount.
Old Nov 16, 2025 | 03:20 PM
HealeyJag's Avatar
Awsome...
one less thing to replace....and think about
Ledmi
May 5, 2025 03:56 PM
Childeric12
Dec 8, 2024 07:53 PM
JaguarXJL15
Sep 5, 2024 10:34 AM
Flex320
XJ XJ12 ( X305 )
Feb 9, 2023 02:18 AM
Flex320
XJ XJ12 ( X305 )
Jan 5, 2023 12:12 PM
