My xk downloads the battery
Old Jun 15, 2019 | 04:39 PM
Jomiltom's Avatar
Default My xk downloads the battery
I have checked the electric consumption at rest of my xk of the year 2008 and I see that consumes 0.30 A. after stopping and closing all the doors. I think it's excessive. Anyone save if it's normal?
Old Jun 15, 2019 | 08:18 PM
Patrick Wong's Avatar
Is the car locked with the fob at least 20 feet away? It may take a little while for the quiescent current draw to drop down to 0.02A or thereabouts. If it remains at 0.3A indefinitely then you have a problem with a stuck relay or similar issue.
Then you would be faced with having to remove fuses to try to narrow down where the current draw is coming from, which sounds like a painful process to go through considering the number of circuits potentially involved.
Old Jun 16, 2019 | 04:54 AM
Jomiltom's Avatar
[font][font]Gracias patrick [/font][font]Acabo de realizar otra medición con un comprobador más confiable y, luego de aproximadamente 3 minutos de cerrar el automóvil, el consumo eléctrico baja a 0.01 A. Creo que mi error fue tener el auto desbloqueado con el control remoto.[/font][/font]
Old Jun 16, 2019 | 04:59 AM
Jomiltom's Avatar
[font][font]He verificado que si no cierro el automóvil con el comando, el consumo permanece en 5.4 A durante aproximadamente 45 min. [/font][font]momento en que comienza a bajar a 0.01 A. Gracias.[/font][/font]
Old Jun 16, 2019 | 08:06 AM
110reef's Avatar
Si cierra la puerta pulsando dos veces el botón de la manija de la puerta, se va a dormir más rápidamente.
Old Jun 16, 2019 | 08:25 AM
Jomiltom's Avatar
Is it not the same to close the door and press the remote control 2 times to close the door and press the door button twice?
Old Jun 16, 2019 | 11:32 AM
Cee Jay's Avatar
All the computers take 30-40 minutes to gradually all turn off whether the alarm is active or car is locked.. That whole 30-40 minutes they still use extra power.
ALSO, if a battery lead is disconnected to insert any Ammeter, that resets all the modules for ANOTHER 30-40 minutes.
Old Jun 16, 2019 | 11:43 AM
Jomiltom's Avatar
I have inserted an amperemeter in series in the negative terminal of the battery and I have closed all the doors, then I have closed the car with the remote control and the ammeter has lowered its reading to 0 in about 2 min.
Old Jun 16, 2019 | 11:46 AM
Cee Jay's Avatar
There must be a lower range setting on your ammeter, as even keeping clock time would take 0.01. Add the alarm, keyless entry and all that other stuff would be up there aways.
Old Jun 16, 2019 | 11:54 AM
Jomiltom's Avatar
It is true that there is a consumption of 0.01A. In addition I already put it in previous interventions. Now I was wrong to write and I put 0 A when I really wanted to say 0.01 A. The important thing is that it does not have an abnormal consumption when stopped and closed.
Old Jun 16, 2019 | 12:11 PM
Cee Jay's Avatar
NEW BATTERY!!!!! That's always the answer. Always. Never is it NOT the answer.
Old Jun 16, 2019 | 02:16 PM
Jomiltom's Avatar
The battery is new. I changed it a month ago. If the battery had been old I would not have considered looking at residual consumption at rest. Greetings.
Old Jun 16, 2019 | 02:52 PM
Originally Posted by Jomiltom
It is true that there is a consumption of 0.01A. ... The important thing is that it does not have an abnormal consumption when stopped and closed.
Thanks for letting us know that your car is OK.
Old Jun 16, 2019 | 04:21 PM
Jomiltom's Avatar
[font][font]Está bien mi auto y lo celebro, aunque esta mañana tuve un alto consumo de electricidad y fue debido a que los cables de un probador están en malas condiciones y mantengo el auto sin cerrar con el control remoto. [/font][font]Te agradezco que me cuentes el consumo en el resto del coche. [/font][font]Me ha sido muy útil. [/font][font]Saludos.[/font][/font]
Old Jun 17, 2019 | 12:32 AM
u102768's Avatar
Not true. Mine shuts down a lot quicker if I lock it which is why I have started doing that even if it is in my locked garage. That seems to preserve the battery enough so that I don't have to resort to my CTEK even with my 4 mile daily commute.
Old Jun 17, 2019 | 06:33 AM
kj07xk's Avatar
If that table is to be believed, then footnote #2 says its about 15 minutes if you have TPMS.
Old Jun 18, 2019 | 01:07 AM
u102768's Avatar
I assume that is more relevant to the cars that otherwise shutdown in 10 minutes.
MikeofBonsall
Sep 24, 2016 07:17 AM
RDMinor
Nov 13, 2014 06:03 PM
ChilledJames
Jul 28, 2013 09:17 PM
kobe3006
Aug 1, 2012 06:34 PM
