New diagnostic toy - HT200
Old Jul 5, 2019 | 08:40 PM
Patrick Wong's Avatar
Originally Posted by Canadacat
Well so much for that, now neither power seat works , nothing I guess I will go for reflash
Have you checked the relevant fuses in the Central Junction Box: F9, F28, F29 for the passenger seat; F18, F30, F32 for the driver's seat.
Old Jul 5, 2019 | 10:03 PM
Canadacat's Avatar
Seems hard to believe that all fuses would blow at once
Old Jul 6, 2019 | 12:19 AM
Its not necessary for all fuses to blow - just for one of the three fuses for each seat to blow.
Its up to you if you prefer to have the dealer tech do the troubleshooting.
Old Jul 6, 2019 | 02:39 PM
Canadacat's Avatar
Well today go for a drive all button s work except for the passenger tilt forward, Gremlins.
Old Jul 6, 2019 | 07:26 PM
ralphwg's Avatar
How is your battery? If it is more than 4 years old it may be time to replace it. Or if it reads less than 12.6V at rest, it is time to replace it. Weak/bad batteries indicate there presence by electrical/electronic gremlins.
Old Jul 8, 2019 | 02:46 PM
Canadacat's Avatar
Battery is six months old but you are right I will test voltage
Old Jul 11, 2019 | 01:56 PM
AlexJag's Avatar
Sponsor
just received my tool yesterday looks like it's can read and do a lot of things.
I noticed you can even calibrate certain modules have anybody done that?
Old Jul 11, 2019 | 03:14 PM
  #28
AVMiii's Avatar
Does the autel reset the oil service message? I have another recently purchased autel unit,(Diaglink, a DIY version of MD802) I also had to download Jag specific software. When I attempt to reset the oil service message, the autel just lists the jag procedure for doing it. So, the autel doesn't really do anything in this respect.
Old Feb 2, 2020 | 07:07 PM
DGL's Avatar
DGL
I've received the Autel AP20 last week. I haven't had much time to test it. Anything new about using it? I've used an ELM123 with torque pro with no problems to monitor oil pressure, coolant temperature, and volts.
Old Feb 3, 2020 | 12:42 AM
  #30
kj07xk's Avatar
Are you sure it was ‘oil pressure’? Didn’t think that was available.
Old Feb 3, 2020 | 06:07 AM
  #31
DGL's Avatar
DGL
I think I installed the oil pressure and oil level parameters manually.
Old Feb 3, 2020 | 10:49 AM
  #32
Sean W's Avatar
Cambo posted a read on some Torque Pro PID modifications one of his associates created for 2010 onward XK's. Oil pressure wasn't one of them. If you were able to add that somehow, you should share it in his thread as others would value that. Maybe it was oil temp you were thinking of?
https://www.jaguarforums.com/forum/g...p-more-213503/
They were:Engine Oil Temperature
Engine Oil Level
Engine Oil Volume (calculated)
Intake Air Temperature 2 (charge temperature post intercooler)
Transmission Fluid Temperature
Rear Differential Fluid Temperature (vehicles with E-Diff only)
Old Feb 3, 2020 | 11:35 AM
  #33
DGL's Avatar
DGL
Engine Oil Level
I think it was engine oil temperature. I entered the parameters from the above link.
euphonium01
Mar 20, 2018 04:41 PM
Mark in Maine
19
Aug 31, 2017 10:54 PM
MaximA
Jul 25, 2016 11:50 AM
Larry_in _Missouri
May 6, 2014 07:30 PM
ejjbee
General Tech Help
Jan 30, 2013 11:34 AM
