New steering wheel
Old Apr 11, 2017 | 03:32 AM
steve_k_xk's Avatar
Default New steering wheel
Time to plush up the XK
Old Apr 11, 2017 | 06:45 AM
Chaos236's Avatar
Pick installed and before / after?
Old Apr 11, 2017 | 08:07 AM
Ian D's Avatar
The steering wheel buttons light up blue don't they? Unless you've done some thing with the green.
Old Apr 11, 2017 | 03:16 PM
steve_k_xk's Avatar
Just got the wheel yet to install
As the car wasn't here this morning and gone by this hour I downloaded a pic of the current wheel I have
I had no idea this wheel is going to light up blue ..I'm really in for a treat now !!
Old Apr 11, 2017 | 03:28 PM
michaelodonnell123's Avatar
No wood?
Old Apr 11, 2017 | 04:42 PM
tberg's Avatar
Doesn't your old steering wheel (like mine) have adaptive cruise control button and the new one doesn't? Where do you put the contacts?
Old Apr 11, 2017 | 07:25 PM
steve_k_xk's Avatar
No adaptive cruise on old wheel
Old Apr 11, 2017 | 09:35 PM
steve_k_xk's Avatar
Originally Posted by michaelodonnell123
No wood?
I've got the silver theme throughout the car wood wouldn't tie in
Old Apr 12, 2017 | 01:22 AM
Ozmag's Avatar
Did you have an issue with the existing wheel?
Old Apr 12, 2017 | 02:15 AM
steve_k_xk's Avatar
Yes I missed that new steering wheel feel !
Old Apr 12, 2017 | 02:45 AM
Parzival's Avatar
lights up blue? mine doesnt..
Old Apr 13, 2017 | 05:06 PM
tnt10's Avatar
Isn't the picture in post #4 of your old steering wheel?
The two thumb-wheel controls on the right side are for ACC, at least they were in my old XKR?
If not, what was the 2nd wheel for? One is for cruise speed, and the other is for?
tnt10
Old Apr 13, 2017 | 05:27 PM
Sean W's Avatar
LMAO, thank you.
Old Apr 13, 2017 | 06:35 PM
steve_k_xk's Avatar
tnt10
Tnt the pic is an image I downloaded as the car had already left for the day I didn't realise it had the four button being the adaptive cruise control when downloading the image
Old Apr 13, 2017 | 07:49 PM
steve_k_xk's Avatar
It's done
Would I do it again ..No
Next time could I live with a steering wheel that has done just over 60k km..Yes
Attached Thumbnails New steering wheel-1492122830746.jpg   New steering wheel-img_20170414_083622.jpg   New steering wheel-img_20170414_083527.jpg   New steering wheel-1492119200032.jpg
Old Apr 14, 2017 | 03:12 AM
steve_k_xk's Avatar
I take it all back !! the car feels that more special with a fresh wheel !!
Highly recommended
Old Apr 14, 2017 | 06:32 AM
steve_k_xk's Avatar
It's confirmed it lights up blue and all xk/r wheels are interchangeable
Old Apr 14, 2017 | 07:39 PM
Fstbmw1's Avatar
Highly recommended
Nicely done…. how long from start to finish for the swap and did you encounter any real obstacle during the swap. Thx
Old Apr 14, 2017 | 08:58 PM
steve_k_xk's Avatar
The lower dash will need to be removed to gain access to the rear of the wheel to pop the clips out
The key is obtaining the correct screwdriver for the job , as the screwdriver has to be inserted and then turned the few I tried seemed to be too narrow.. although with perseverance I prevail and actually bent the driver from the sheer force .
A screwdriver with a wider tip will make this job a little easier
Old Apr 15, 2017 | 05:57 AM
Ian D's Avatar
I just fitted a heated steering wheel to my car and found the airbag an absolute pain to remove, took over 30 minutes. Getting one side to pop out was the easy bit, then suddenly the airbag just jumped forward both sides.
Just waiting on it getting programmed and I'll have heated steering.
