New wheels on a 2010 XK
Old Nov 22, 2014 | 09:11 AM
dougsjag's Avatar
I trial fitted the wheels and I have a few issues.
1. Original nuts do not fit in the counter bored hole of the new wheels. See attached pic. I'll have to find some new nuts.
2. I ordered the spacers 20mm thick and this is too much for the look I want. I won't go thru the details of the stack up but basically with a 15 mm spacers up front and none in the rear, the wheels will be sitting 15 mm further out up front and 10 mm in the rear.
3. The spacers and rings fit perfectly with a nice snug slip fit. No feel able play.
4. I have plenty of space in the wheels for the cars studs to stick out beyond the spacer and not interfere with the wheel.
5. One wheel has rim damage. I didn't know what to expect from the vendor I purchased from on eBay, but the experience, so far, has been stellar. They will replace the wheel and I can keep the damaged one. 2-3 weeks to get the new wheel so I am taking the damaged one to a local wheel repair shop this morning and see what can be done for what price. I have attached a pic.
So on we go...
Attached Thumbnails New wheels on a 2010 XK-wp_20141120_001.jpg   New wheels on a 2010 XK-wp_20141120_002.jpg   New wheels on a 2010 XK-wp_20141120_004.jpg   New wheels on a 2010 XK-wp_20141120_006.jpg
Old Nov 22, 2014 | 11:52 AM
GrtShrk's Avatar
Doug,
Really like your "pioneering" spirit. Without people like you willing to try new things first, I'd be lost modifying my car.
For the record, two days ago I "broke the rules" and installed H&R 15mm spacers on all 4 wheels of my '12 XKR (20" Takoba's). Results are spectacular.
With 15mm spacers installed.
Stock (no spacers)
Old Nov 22, 2014 | 07:37 PM
RedRider48's Avatar
That's a nasty little "ding" ya got there mate. Me thinks, a good wheel shop can fix that, though.
I spent $600 to get my Cremonas ship-shape, as one was cracked. So, for $600 *******, I now have another set of wheels and tires for me Jag.
When I replaced my wheels, I too, I needed to order correct lugs. I still have my OEM lugs to go with the Cremonas.
Good Luck with your fix.....
Old Nov 22, 2014 | 08:57 PM
richzak's Avatar
You will most likely need to secure a set of "tuner" spline type lug nuts for the new wheels.
I had to buy the same type for the aftermarket wheels on my 2009 Jag XKR PE.
They are available from Amazon. Be sure to buy a good quality set, as quality does vary.
Old Nov 23, 2014 | 10:14 AM
dougsjag's Avatar
I went down to Wheel Specialists in Tempe Saturday morning and was quoted $200 for wheel repair and no guaranty the would not crack during repair rendering them useless, so that was an easy call. I will check some other places.
I have measured the front wheel face location again and came up with new numbers. Measure twice right? bottom line is that I now need an 8 mm spacer. I will modify the 20 mm pacers that I had made.
The damaged wheel is usable according to Wheel Specialists.
I bought a new se of splined lugs. Thanks Richzak. Thanks GrtShrk for the thumbs up.
I now believe that the wheel face location varies on the 2007 and up KXs depending on the wheels (20s, 19s, staggered or not?) and other variables. I think that it would be best to provide the distance between the wheel face and the outside surface of the body at the wheel to properly compare spacer requirements.
So at this point, I may go ahead and install the wheels with the dinged wheel and wait the 2-3 weeks for the new one to be installed.
Have a great Sunday.
Old Nov 23, 2014 | 10:17 AM
dougsjag's Avatar
By the way, a funny thing occurred while checking the front wheels again. I could not get my jack under the jag in the front where the jacking location is. Never happened before. Looked like it was sitting lower. original tires installed and full of air. Hummm.
Old Nov 25, 2014 | 07:18 PM
powerhouse's Avatar
bought a set of H&R wheel spacers today, i'm putting 20mm on the front as i want the wheels flush with the wheel arch and 15mm on the rear. I used a straight edge against the wheel arch and measured the distance in to the rims I've on , so should be good. Does anyone know what the torque setting for the nuts on these spacers.
Attached Thumbnails New wheels on a 2010 XK-cannonball-4.jpg   New wheels on a 2010 XK-dsc_0081.jpg
Old Nov 25, 2014 | 09:54 PM
  #28
dougsjag's Avatar
I would/am using the torque required for the wheel nuts.
Old Nov 25, 2014 | 10:24 PM
richzak's Avatar
I think it is 90lbs but not 100% certain.
Old Nov 26, 2014 | 06:57 AM
  #30
R_Rated's Avatar
Be EXTREMELY weary of non-forged wheels in our heavy, torquey cars.
Old Nov 26, 2014 | 07:52 AM
  #31
Stuart S's Avatar
92 per the 2009 Owners Handbook.
Old Nov 26, 2014 | 09:05 AM
  #32
dougsjag's Avatar
My stock Jag wheels are not forged. There are different quality levels and processes of cast wheels though. Low pressure casting is the acceptable process for almost all high performance OEM wheels.
Old Nov 27, 2014 | 08:13 PM
  #33
dougsjag's Avatar
Thanks for the reply, I'd like to know how it works out. Thanks for pics.
Old Nov 28, 2014 | 01:01 PM
  #34
Ngarara's Avatar
The only stock XK forged rims are Vortex & Vulcan, as far as I know.
Old Nov 29, 2014 | 11:29 AM
  #35
R_Rated's Avatar
Perhaps. But rarely do you see oem wheels break and you do get what you pay for with wheels.
Most inexpensive wheels are designed for much lighter cars equipped with VTec and then fitted to cars like ours.
Old Nov 29, 2014 | 02:06 PM
  #36
damienedwards's Avatar
Guys with 15mm spacers.......how does ot effect the handling??? My experience of them on a few cars was that it tends to increase the tramling and squirm under heavy braking........does seem to depend on the car though as sometimes its barely noticible
Old Mar 14, 2015 | 06:33 PM
  #37
dougsjag's Avatar
Well...I finally got the wheels on. Very happy with them. The outside face of the wheels sit 15 mm beyond stock and I love the look. Here are some pics. By the way the car drives and handles like original.
I'll try and get the car out and get some better pictures soon. I just had hip replacement surgery 17 days ago and still under some restriction.
Attached Thumbnails New wheels on a 2010 XK-dsc07964.jpg   New wheels on a 2010 XK-dsc07966.jpg   New wheels on a 2010 XK-dsc07968.jpg
Old Mar 14, 2015 | 11:24 PM
  #38
Ngarara's Avatar
They look good. Hope your recovery goes well and you're back behind the wheel ASAP.
H20boy
Dec 24, 2024 03:23 PM
Dagny
Jun 11, 2024 01:06 PM
08Z06
Oct 24, 2015 05:46 PM
Jaiello21
Sep 14, 2015 09:42 PM
Mike Green
Sep 7, 2015 12:39 AM
