No start
Old Sep 12, 2025 | 04:05 PM
slb07jagxk's Avatar
Default No start
I replaced the battery in my 2009 XKR
It will not start. all lights on dash come on but when pushing the start button, nothing!
What have I done wrong?
Old Sep 12, 2025 | 07:01 PM
Sean W's Avatar
what does the voltage at the battery terminals read?
Old Sep 12, 2025 | 07:09 PM
sov211's Avatar
Unless you charged the new battery before installation, AND verified that the battery connections are tight and secure, the battery is still the main suspect. New batteries are very rarely fully charged when purchased - and the electronic modules in your XK require a steady diet of full voltage
Old Sep 12, 2025 | 07:43 PM
slb07jagxk's Avatar
It does everything but start
Old Sep 12, 2025 | 10:25 PM
McJag222's Avatar
How hard is the brake pedal to depress? - you may have to stomp on it.
You could also try a disconnect of the battery for a few minutes to try a "hard reset" - some people like to short the battery cables together after disconnection.
Old Sep 12, 2025 | 10:31 PM
Stuart S's Avatar
Try this: When you get in the car, DO NOT step on the brake pedal. Press and hold the START button and keep holding it while the dashboard lights up and you then press the brake pedal as hard as you can. Hopefully, it'll start.
Old Sep 18, 2025 | 05:16 PM
slb07jagxk's Avatar
It finally started, not sure what I did but know it starts.
Thanks to all your suggestions!
Old Sep 19, 2025 | 08:26 AM
Stuart S's Avatar
That's the first sign ... not remembering what you forgot
Brendonbrett91
Apr 25, 2025 07:08 PM
DESTROYER77
XF (X260)
Aug 5, 2021 05:37 PM
DESTROYER77
XF (X260)
Aug 5, 2021 05:31 PM
bigd1977
Jun 13, 2021 06:17 PM
evasive
Jul 26, 2013 09:47 AM
