A non-Cambo OBD gauge solution
Old Nov 11, 2020 | 04:28 PM
mhminnich's Avatar
Default A non-Cambo OBD gauge solution
After having a close call with a valley hose letting go, and NO observable data that something was amiss, I went for one of the cabled OBD gauges. Sorry CabrioBob, I wanted something promptly!
I fashioned a simple bracket which slides snugly between the dash and center console without damaging anything in the process, and removed the existing gauge cover for clearance. It is easily observable from the 3-6 opening in the steering wheel while driving and provides me with the audible warnings as well.
Old Nov 11, 2020 | 05:07 PM
panthera999's Avatar
Can you identify the product and source? Thanks
Old Nov 11, 2020 | 06:55 PM
mhminnich's Avatar
It is the Auto tool X50.
About 35 bucks on Amazon.
Old Nov 11, 2020 | 08:36 PM
DGL's Avatar
DGL
I like how you mounted it- - very clever. I looked at one of these last year but never wanted to have a cable going to the top of the dash; however, I like where you installed it. Can you tell us if it completely shuts down when the car is off. Some devices that connect to the OBD2 port never turn off. The device may go off but still have a low power connection.
Old Nov 11, 2020 | 09:03 PM
Bill Mack's Avatar
Cambo is amazingly clever, true, but are we talking about the device created by Cabrio Bob?
I found something called the AUTOOL X50 PLUS online, but nothing called Auto Tool. Is this the same thing?
Old Nov 12, 2020 | 05:16 AM
barnsie's Avatar
This is an inexpensive and useful solution, but it lacks the elegance of Cabrio Bob's ADU. HST, any kind of display of vital info is a good thing IMO.
Old Nov 12, 2020 | 05:21 AM
barnsie's Avatar
I do like the display of mhminnich's unit though. I may install one of these in my daily X-Type.
See it here on eBay
Old Nov 12, 2020 | 08:44 AM
mhminnich's Avatar
Apologies to CabrioBob and his superb solution! I can't believe I screwed that name up.
Yes, it is the Autool X50.
As to shutting down , it goes into standby mode 30 seconds after the car shuts down. It's a black screen at that point and I couldn't tell you if it is still drawing power.
Old Nov 12, 2020 | 10:35 AM
Bill Mack's Avatar
I'm in for Cabrio Bob's third round of ADUs. I already use the VGate OBDII Interface that Bob recommends to pair with his unit, but I don't like having to fiddle with the iPhone while driving.
mhminnich, your alternative is certainly cheaper and probably provides a lot of data, but Bob's solution is elegant and attractive. To put it more basically, it's slick as snot!
Old Nov 12, 2020 | 10:56 AM
barnsie's Avatar
Glad you got in on Bob's third (and final) round, Bill. The ADU is crazy good.
Old Nov 12, 2020 | 10:17 PM
Stuart S's Avatar
Agreed, but in my XKR the ashtray is already occupied by my backup cam display.
The Autool X50 Plus is the perfect solution at a low price! I just ordered one from Amazon at 5% off.
Amazon Amazon
Old Nov 12, 2020 | 10:28 PM
Cee Jay's Avatar
I have all my stuff on my TSD, gauges and backup camera.
Old Nov 12, 2020 | 10:40 PM
Sean W's Avatar
me too
Old Nov 12, 2020 | 10:53 PM
Stuart S's Avatar
Originally Posted by Sean W
me too
That's the best solution, but it's waay above my DIY ability level. And the cost difference is substantial, just for the parts. My backup cam was $125 and the Autool X50 Plus was $35, or $160 all in with less than 30 minutes to install both. Sure, it's not the greatest but it works for me.
Old Nov 13, 2020 | 05:14 AM
barnsie's Avatar
https://www.amazon.com/dp/B07L8HMKKG..._hpGRFb6RN7236
Ah yes - I had forgotten your backup camera display, which is also a neat use for the ashtray. I am close to ordering the Autool X50 for my X-Type. It looks like an interesting device and I'd like to see one in the flesh / plastic.
Old Nov 13, 2020 | 05:15 AM
barnsie's Avatar
That is the holy grail of additional displays IMO. But it is waaaaay beyond my DIY ability unfortunately.
Old Nov 13, 2020 | 05:17 AM
barnsie's Avatar
Hunting around, I found these threads which have similar themes and some additional ideas for adding extra displays.
https://www.jaguarforums.com/forum/x...lgauge-216733/
https://www.jaguarforums.com/forum/x...-gauge-210411/
Old Nov 13, 2020 | 06:28 AM
gyl30's Avatar
C'est la solution que j'ai adoptée ...
Facile à installer et parfaitement lisible!
A gauche sur la photo en bleu la température de l'eau et à droite en blanc la vitesse
Old Nov 13, 2020 | 07:44 AM
ThreadLock's Avatar
me too
Sorry Guys... How is this achieved??
Old Nov 13, 2020 | 09:11 AM
Bill Mack's Avatar
This is Sean W showing some of the capabilities of his upgrade. It requires that you add a couple of gadgets to the OEM infotainment unit (the unit running the touchscreen). I have NOT attempted this upgrade, so there are others - Sean W, Cee Jay, others I'm sure - much more knowledgeable about how to do it. And there may be other ways to get similar capabilities on your touchscreen display.
All of these solutions start with adding an OBDII scanner to the car. The simplest way to get readouts like this is to install a Bluetooth scanner and an iOS or Android app that shows data on your phone. Simple and cheap, yes, but not as elegant and easy to use as these more sophisticated solutions.
