OBDii/Gauges
Old Dec 26, 2015 | 07:15 PM
chXFS's Avatar
Here are mine. I started a thread in the XF side. By buddy makes the pods and I used the Aeroforce gauges. They read 30 different perimeters. I have them set up to read two per gauge. Boost, AFR, Coolant, and Intake temp.
Attached Thumbnails OBDii/Gauges-image-709430216.jpg   OBDii/Gauges-image-4006117556.jpg
Old Dec 27, 2015 | 10:56 AM
britannia's Avatar
Sean,
Yes, your right! Found a picture on my Alldata account; so I would need the V8 adapter block (JagWrangler.com) to add a pressure tap ( mech or electronic).
Another project.......................not too hard.
UltraGauge has not arrived yet ................
Why does Jaguar do things like no gauges on XK's (my wife's XK8 has them!)
Continuous improvement unknown at Jaguar!!
Cheers, Adrian
Old Dec 27, 2015 | 11:11 AM
Sean W's Avatar
Originally Posted by britannia
Sean,
Cheers, Adrian
Not just Jaguar. Though most of the high end cars were holdouts, car makers have shifted back to the idiot light concept simply because "most" people, ignore the gauges, although IMO those same people would ignore idiot lights. Heck, even before reverting back to light warnings, many gauges were simply "feel good" and weren't necessarily accurate (My 05 Super V8 coolant temp is an example of that). Car warms up, gauge goes to the middle and stays there unless there is a crisis.
Also, per several manufacturers, lights on modern vehicles function under tighter controls so theoretically, they're a more effective warning system, whereas a gauge has no alarm.
I personally can live without the oil pressure gauge. In 45+ years of driving, losing oil pressure has never been an issue so I will accept the idiot light on that one.
I would however like to view coolant temp and battery voltage. Those two are still on my wish list.
Old Dec 27, 2015 | 11:16 AM
Sean W's Avatar
Thanks chXFS. I went to the other post There's some pics of the single pod, no double pod as you have above and no mention in those posts of the cost of the dual pods. The gauges are pricey, but there are several options there. I prefer the glowshift as the color scheme is more in line with Jaguar instruments (green light on Black) in the case of my car.
What does your friend charge for the vent mount dual pods?
Old Dec 27, 2015 | 11:40 AM
Fstbmw1's Avatar
Hi chXFS, are your gauges obdii or 'mechanically' driven? Any issues with running the wiring? I would love to see the backside of the gauges to get a sense of the over all look of the pods. Seems like a nice set up.
Old Dec 27, 2015 | 08:20 PM
chXFS's Avatar
Originally Posted by Sean Wagstaff
Thanks chXFS. I went to the other post There's some pics of the single pod, no double pod as you have above and no mention in those posts of the cost of the dual pods. The gauges are pricey, but there are several options there. I prefer the glowshift as the color scheme is more in line with Jaguar instruments (green light on Black) in the case of my car. What does your friend charge for the vent mount dual pods?
I know the gauges are pricy but they read 30 perimeters and you can scan your car for codes and clear them as well. I noticed you mentioned you want to match your green interior lights. They do offer my gauge in green. A single pod will cost you $85.
Old Dec 27, 2015 | 08:29 PM
chXFS's Avatar
My gauges are OBD2. No issues running the cables. Remember, you would have to send him your vent and he will mold the pod to it. So all you do is run the cables down the hole were the vent was and plug the vent back in with pod attached and your done. Now all pods come back black. So to give you an idea my dash is Oyster, so I ordered Oyster leather dye and took to Lowes and had them make into a paint. Then I used a aresol kit to spray the pod the color of my dash. It came out OEM. Here are a few pics so you get the idea.
Attached Thumbnails OBDii/Gauges-image-2215192279.jpg   OBDii/Gauges-image-2034921861.jpg   OBDii/Gauges-image-993516542.jpg   OBDii/Gauges-image-2674219377.jpg
Old Dec 27, 2015 | 09:57 PM
  #28
Fstbmw1's Avatar
Thanks for your quick response chXFS. I have my car up on my storage lift with the bumper off as I'm waiting for an updated front grille. Over the next few days when I have some time I will set it down and poke around the interior of the car. I would still like the gauges on my A pillar but need to determine how the cable routing will work for the pillar. I went to the XF site and noticed that there is an email add for the fella who does the pods. I think I will send him a note to see if he may be interested in moulding the pods into my spare A Pillar. Good to know if I may have a choice between vent and pillar. Thanks for the pics.
wrair
Jan 17, 2024 01:55 PM
Rhett
Oct 25, 2021 05:07 AM
Joe Gandalf
Dec 4, 2015 05:58 PM
David7
Nov 30, 2015 10:24 AM
yellowapple
Nov 29, 2015 04:29 AM
