Observation on my torque pro gauges
Old Apr 14, 2015 | 07:37 PM
jagtoes's Avatar
Default Observation on my torque pro gauges
Yesterday while driving I did a little comparison of my torque pro volt gauge with a plug in volt meter in my glove box. Now there are 2 voltage gauges in the torque pro . One is CM volts ( I assume control module) and the other is AD volts. I assume the AD volts are more uncontrolled because the voltage was between 14V to 15.5 volts. The CM voltage was always at 13.4-13.5 throughout the 30 minute drive. Also plugging in the volt meter in the glove before start I had 12.5V . The volt meter would also read .2 volts higher then the torque pro.
Next was water temp which I was surprised on how fast it warmed up. I would say within 2-3 minutes it was at 140*F and in 6-8 minutes it was at 195*F. It ran at 195*F +/- 2*F in all conditions and outside temp was 65*F.
Last was the AFR which was at 14.76 during my parkway ride at 55mph with CC on.
It was a great sunny day and the golf was great.
Old Apr 14, 2015 | 08:18 PM
axr6's Avatar
I always read the CM voltage on my Torque Pro. 12.5 V before start is a nearly fully charged battery voltage.
My coolant temps also ran around 195 F on flat roads but, increase quite rapidly as I start climbing one of the local canyon roads. In a matter of 2-4 minutes of mid-range RPM driving I am over 225F. AFR of 14.x is perfect for cruising.
I had one issue with my Torque Pro and its adapter, thus far. When I was doing a 200 mile drive in my XKR over varying altitudes, up and over 7000 feet, I had a warning light pop up on my dash while the ELM327 adapter was plugged into the OBDII port. Finally, I stopped the car, shut the engine, removed the ELM327, restarted it and the warning disappeared. Seems like the ELM327 caused some interference there.
Old Apr 14, 2015 | 10:48 PM
Ngarara's Avatar
IIRC, the 5.0 engine was specifically designed for fast warm-up - I think it's because the oil cooler is a water/oil heat exchanger rather than using airflow, so it can actually act as an oil heater during the warm-up phase.
Old Apr 14, 2015 | 11:08 PM
Cambo's Avatar
Funny thing about the measured voltages, I noticed something similar with my Land Rover, +0.2V difference between Torque and the measurement at the battery terminals. Both with the ignition on 12.6V / 12.8V, and with the engine running 14.2V / 14.4V
I guess there is a bit of voltage drop down the cables to the modules.
Old Apr 14, 2015 | 11:13 PM
Ngarara's Avatar
The 5.0 cars might have a more accurate reading, since the battery monitor sits right on the terminals.
Johnken
Apr 8, 2018 10:21 AM
workworkwork
Oct 23, 2015 10:26 AM
vwbusbits
Oct 13, 2015 03:43 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
