ODBII and convertible operation debugging
Old Aug 28, 2022 | 12:39 PM
tommytarget's Avatar
Default ODBII and convertible operation debugging
sorry if this was covered somewhere else or is a dumb question. my 2007 xkr convertible roof is working intermittently. i have read threads about the operation ... the manual reset helped a bit. but i will probably take to a professional. but i have a specific question before i do.
in the service manual it mentions data logger functions during the various stages of the convertible operation ...
eg Data-Logger: Convertible
Top position sensor inputs – Front latch open sensor - INACTIVE
so i was wondering if these are things that i can track and diagnose via the ODBII port using a purchased scanner or wireless ODBII scanner with a mobile APP ( i currently have one of those but it just gives engine codes)
thanks in advance
note the main issues i am seeing are
- quarter windows rarely come up even if the rest of the operation works properly
- tonneau cover sometimes does not open ( both when trying to OPEN the roof and when trying to CLOSE the roof )
- i also occasionally get the "hood not closed error" but i can usually make that go away by playing with the switch
Old Aug 28, 2022 | 01:30 PM
JagV8's Avatar
Probably need at least SDD.
Old Aug 28, 2022 | 01:36 PM
ok thanks you. i'm new here (last post was the first one). i have updated my signature line (i think) ... thanks for the tip!
and thanks for the information on needing the SDD ( and the link to the acronyms ).
oh well.
Old Aug 28, 2022 | 07:36 PM
V7Sport's Avatar
oh well.
see the SDD link in the General Tech forum. Lots of info there
Old Aug 29, 2022 | 11:37 PM
ralphwg's Avatar
There is a convertible top expert on this forum. His handle is whitexkr. You can pm him if you have enough posts. In addition, he has invented a one touch remote convertible top app which is quite reasonable and not difficult to install. You can check out the remote/one touch top app at thejaguarwrangler.com
Furthermore he is a very nice guy and very helpful. A lot of forum members (including me) have his top application including some hardware installed. Good luck.
Old Aug 30, 2022 | 06:50 AM
silvertonesx24's Avatar
My $30 autel ht200 scanner had all the same convertible codes as my SDD when my top started acting up.
My issue was either related to low battery, or not having the windows properly programmed.
Old Aug 30, 2022 | 09:14 AM
thank you very much. i spent some time following the various thread and saw a lot of advice from whitexkr
i think i will be buying that module today!
Klaus0401
Mar 24, 2025 10:02 PM
Phil m
Aug 9, 2021 04:23 PM
Rchuda
Jun 14, 2021 04:00 PM
brinny
Apr 5, 2020 09:47 AM
JP64
Oct 22, 2017 10:27 AM
