Odd puff of smoke
Old Jun 10, 2024 | 08:54 AM
markva44's Avatar
Question Odd puff of smoke
On a couple of occassions I have noticed that if I start the car then move it a few feet, turn it off and then restart it later there is a puff of smoke for a few seconds, obviously my heart skipped a beat.. It doesnt do it at any other time. Its a 2007 XKR with 60,000 miles FSH.
Ive had older cars in the past and when it was valve seals the car smoked literally all the time on startup
Any ideas please?
Old Jun 10, 2024 | 09:33 AM
Stuart S's Avatar
What color is the smoke? If it's white and doesn't last long, it's probably water vapor and it's normal. A by-product of internal combustion of gasoline is water vapor, which upon shutting off the engine collects in the exhaust system. That's why you occasionally see water dripping out of the exhaust pipes of older cars. The heat from starting a cold engine cuauses the water in the exhaust system to boil out as steam vapor, which is the white smoke you see.
Old Jun 10, 2024 | 09:41 AM
Cee Jay's Avatar
Could be extra fuel from shutting down while in whatever 'loop' is for cold start-up. Open? Closed???
Old Jun 11, 2024 | 04:09 AM
guy's Avatar
guy
@markva44 , Like you said… its an 07. I have first hand experience with this. But as its just at startup and the level of oil barely drops between oil changes. (does not even need .25 l) I’m not going to worry about suggesting open heart surgery yet.
Look at it as “additional lubrication”, lol.
Out of interest, what oil are you running? Car calls for WSS-M2C-913B 5W30. But, I only used synthetic. Perhaps that is why that startup puff is just starting now, at 160,000 kms.
Cheers.
Old Jun 16, 2024 | 06:00 AM
markva44's Avatar
Hi. Im using Castrol GTX 5W-30 5W30 A5/B5 Fully Synthetic
Old Jun 16, 2024 | 08:12 AM
guy's Avatar
guy
sure. Was that being run its entire life? Was the first oil change done at 1000kms? the second at 2500??
We have 3 situations against us: wear, tear and age.
Old Jun 16, 2024 | 09:24 AM
markva44's Avatar
The smoke was not the blueish valve seal smoke with a smell it was more grey which makes me think its the cold start cycle, as the car was cold when it happened, took it out my garage, went in the house to get my wallet then restarted, greyish smoke.
Old Sep 9, 2024 | 12:48 PM
sony2000's Avatar
Check your PCValve. Change it time?
Old Sep 9, 2024 | 01:19 PM
XKDreams's Avatar
Burning oil has a mod distinct gray than white color. Whereas the white is more water vapor. Burning oil smoke is more persistent , whereas water vapor dissipates in the air more quickly.
Old Sep 9, 2024 | 01:41 PM
Cee Jay's Avatar
True, but RING oil burning is persistent. If the valve guides are the oil problem, then the blackish smoke will only be on a cold start, and only for a couple seconds.
Old Sep 9, 2024 | 02:03 PM
XKDreams's Avatar
Sorry, I meant oil smoke does not dissipate as quickly as water vapor after exiting the exhaust.
Old Sep 10, 2024 | 02:47 AM
RichardS's Avatar
Surely that is exactly what you said the first time? 🤔
Richard
brinny
Dec 17, 2023 09:22 AM
peterg19
Jan 21, 2016 06:56 AM
SkipM
Jun 21, 2011 01:49 PM
cpm53
May 1, 2011 06:09 AM
jxnslotcar
Apr 23, 2008 04:38 PM
