Passenger door difficult to open
Old Dec 9, 2017 | 08:48 AM
trkyam's Avatar
Default Passenger door difficult to open
Anyone have a fix to make the doors open easier?
Ive lubed all the accessible joints and.latches
but from time to time the door requires alot of force
to open...
Old Dec 9, 2017 | 10:11 AM
Ranchero50's Avatar
Does the window drop a little like it should?
Old Dec 9, 2017 | 12:07 PM
Cee Jay's Avatar
Clean and condition all the rubber seals! Sometimes they get sticky and grab the door jams.
Old Dec 9, 2017 | 01:33 PM
Sean W's Avatar
+1. Is the door also hard to open with the window down?
Old Dec 9, 2017 | 04:55 PM
trkyam's Avatar
yes, even with the window down
difficult to open, the.handle itself
feels stuck at times
Old Dec 9, 2017 | 04:59 PM
NBCat's Avatar
Has the vehicle had any body work done to repair damage?
Old Dec 9, 2017 | 10:23 PM
Sean W's Avatar
Yep, that's where I was going next. Also how about some pics of the door gaps if you can?
Old Dec 9, 2017 | 10:39 PM
trkyam's Avatar
no bodywork to my knowledge,
the difficult in opening is in the latch and handle
itself, not so much the door, the initial pull is difficult.
Old Dec 10, 2017 | 07:41 AM
pwpacp's Avatar
Does it pull hard from the inside handle as well or at least feel different from the drivers inside handle? If the same condition exists from both locations I would suspect the door latch since it is common to both. I'm pretty sure cables are used to operate the door latch from each of the handles.
Though I have no experience in dealing with this issue, it may be an indication the latch unit is wearing out. There are also electrics and solenoids assosicated with the lock system but I don't see how that would have an effect on latch release.
Old Dec 10, 2017 | 09:04 AM
davchr's Avatar
Does it close easily, with just a light push? Or does it require some effort to close? Compare it to the passenger side door opening and closing.
If closing is OK then there is probably an issue with the release mechanism or sticking to the weather stripping.
If both opening and closing are difficult look for evidence of wear on the striker on the door jamb. That indicates a door, latch, or striker alignment problem, which is a sign of bodywork and can be a real PITA to solve.
Old Dec 10, 2017 | 10:41 AM
Ranchero50's Avatar
If the latch won't physically release easily I'm going with misalignment of the stud to latch or gummed up latch. Inspect the stud. If it's wearing heavy on one side it may need adjusted or the hing pins may have worn.
It's kind of funny / sad that the passenger doors take a beating but the drivers stay OK in spite of being opened more often.
Old Dec 10, 2017 | 06:42 PM
ralphwg's Avatar
Inevitably I have to remind passengers to desist from using the door window to close the door. Years ago my daughter had a Subaru Outback with frameless windows when she was in college. Eventually every window mechanism had to be replaced at a total cost of $900 on a $22K car. Lesson learned by all involved.
Old Dec 10, 2017 | 10:24 PM
shemp's Avatar
Mine has the same issue on the drivers side. About 3 out of 5 pulls on the outside handle is hard. Locked or unlocked, same deal.. The rest of the time it's smooth as butter. Inside handle opens easily with no extra force every time. I was actually going to take off the door panel and look inside today but got sidetracked...
Old Dec 22, 2017 | 12:32 AM
trkyam's Avatar
Shemp, any luck on pulling off the door panel?
Im having the exact same problem as you.
thanks
Old Dec 22, 2017 | 02:41 AM
My 2007 XK Coupe was the same. Silicone spray on the "leg" at the rear of the outside door handle would ease it for a while but not completely solve the issue:
Non Keyless door handle
Keyless door handle
I just put it down to infrequent use of the passenger door.
Old Dec 22, 2017 | 07:38 AM
shemp's Avatar
thanks
Mine is on the driver side so it's probably not from infrequent use. The passenger side is still perfect, go figure.
Anyways, no I haven't got the panel off yet but I did spray some lithium grease in and around the inside of the door latch. Seems to be better but it's only been a few days...
I'll try Graham's solution as well.
Old Dec 22, 2017 | 10:16 PM
Queen and Country's Avatar
Was this car possibly owned by Roy Moore?
Old Dec 23, 2017 | 11:58 AM
Sean W's Avatar
please save the political comments for the off topic section. It's depressing enough in day to day. This forum is my happy place.
That said - good one.
chuckjag
Apr 16, 2017 09:45 AM
kimsxj8
May 21, 2016 09:54 PM
thegirlh20
Jul 19, 2012 09:46 PM
charm11
Feb 15, 2011 07:51 PM
GrafShutka
Nov 19, 2010 08:12 AM
