Pedestrian Impact System
Old Jul 4, 2023 | 03:45 PM
Ade1009's Avatar
Thumbs up Pedestrian Impact System
Hi,
I have a xk dynamic r, which in cold and wet wet weather display a message to check pedestrian impact protection, during warm weather the warning doesn’t appear. I have the supercharged version, so access to the front impact sensors is not possible from inside the engine bay, due to the supercharger cooling infront of the main radiator. Is there a way of checking if these sensors are at fault with an OBD2 diagnostic, and how do you access the sensors if they are faulty. Any advice will be much appreciated.
Old Jul 4, 2023 | 05:00 PM
J.J.'s Avatar
You need a professional scanner, cheap ones can't access pedestrian fault codes. I've used Launch x431.
Old Jul 5, 2023 | 01:22 AM
Ade1009's Avatar
Thanks, by cheap ones, do you mean under £30, which claim to do everything. Thanks for the tip, save wasting money👍
Old Jul 5, 2023 | 03:01 AM
JonWat's Avatar
Originally Posted by Ade1009
Hi,
I have a xk dynamic r, which in cold and wet wet weather display a message to check pedestrian impact protection , during warm weather the warning doesn’t appear. I have the supercharged version , so access to the front impact sensors is not possible from inside the engine bay, due to the supercharger cooling infront of the main radiator. Is there a way of checking if these sensors are at fault with an OBD2 diagnostic, and how do you access the sensors if they are faulty. Any advice will be much appreciated.
I had the codes read & the sensors replaced by Mistermatic in Fforestfach last December, costs were £55 to read the codes, £225 for 2 sensors & £70 labour to remove & replace front bumper & undertray. A cheap OBD2 code reader will read the engine codes only.
freeb1703
Jul 29, 2022 06:40 PM
bjg625
Dec 14, 2019 02:28 PM
Staatsof
Jan 9, 2014 12:44 PM
Bowmanconsult
Jan 11, 2013 10:55 AM
ThomasX
Mar 11, 2011 02:37 AM
