Play in Seat
Old Jan 10, 2013 | 12:29 PM
mosesbotbol's Avatar
Question Play in Seat
No, not that kind of play....
The seats as if there is a hint of play front and back on the driver's seat. What do I do to tighten it down? Can it be tighten or is it my imagination?
Old Jan 10, 2013 | 12:45 PM
Brutal's Avatar
As long as the 4 mount bolts are tight, there will always be soem play. It has to have some or the gear train and mechanism would bind
Old Jan 10, 2013 | 02:21 PM
damienedwards's Avatar
Should be no play in the seats.............As the mech is constantly under tension.. May be some loose squab to cushion bolts or worn gears.......... Pain in the but to get to the bolts though..... What type of seats do you have?? How old is your car buddy??
Old Jan 11, 2013 | 06:37 AM
I have the optional seats in '07 with the holes in the leather. Car has 24K miles.
Old Jan 11, 2013 | 07:39 AM
Brutal's Avatar
Define play
Old Jan 11, 2013 | 10:44 AM
Originally Posted by Brutal
Define play
Feels like seat cushion can slide fore-aft a little, not the sliders or mechanized part.
Old Jan 11, 2013 | 11:00 AM
Ah ok....... I contract at Lear currently in the UK who make the seats for Jag....... Nice seats btw!!!! They are the perforated premium leather seats with bolster adjust then....... Um there should be no movement in the cushion either....... Worst case it's again worn drive gears........ Best case the bolts to the cushion pan are loose and just need tightening. Hard to check with seat in vehicle so best to have it out and take a look....... If you could post a video it would help buddy.
Old Jan 11, 2013 | 01:45 PM
Assuming it is the best case, I don't think it is worn gear, what now? Can I tighten the cushion pan bolts easily?
Old Jan 11, 2013 | 03:44 PM
plums's Avatar
On mine it was one of the front seat rail to floorpan bolts. The other three were tight. The seat felt like it was rocking every time speed changed.
Old Jan 11, 2013 | 04:53 PM
Brutal's Avatar
Theyre not bad moses, but like he said you have to remove the seat. 4 bolts a few connectors and leave the seat belt attached. Just dont twist the seat around while out or youll twist the seat belt. You can see and access the lower seat mounts underneath with the seat upside down. You may have to move a couple trim pieces. Or wiring. I know by seeing
Old Jan 12, 2013 | 03:30 PM
yup.. Brutal is bang on......... Disconnect the battery before messing too.......... I've seen a number of seat airbags go off...... They work very well!!!!! its a case of grabbing at bits and seeing what has any play in it......
Old Jul 24, 2020 | 04:53 PM
DannyJ's Avatar
Mosses, did you ever resolve that? Seems I experience some play too., slight tilt when hard start/stop
Old Jul 25, 2020 | 05:19 AM
MarkyUK's Avatar
Holy thread resurrection Batman!
DannyJ 6.5yrs on and Moses still has the car, so will assume he got it sorted.
Have you followed the advice on this thread btw?
Old Jul 25, 2020 | 02:39 PM
DannyJ's Avatar
Yes he still has the car that's why I woke up the thread
and yes I removed the seat, checked all bolts.
The culprit is the track itself. Not sure if it is part of the British design and need to live with it or could be amended
Old Jul 26, 2020 | 04:59 AM
MarkyUK's Avatar
OK consider replacing it then, make a call to the dealer tomorrow and get a price/part no, then google if there are any available
Like this for example:
https://www.ebay.co.uk/itm/Jaguar-XK...AAAOSwYlRZLHf0
Old Jul 26, 2020 | 10:34 AM
No. The car had the play right up until I traded her in on an Evora. Was really frustrating and made the trade-in even better as there was no way I would've owned the car for long time with that play in the seat.
Old Jul 26, 2020 | 02:52 PM
DannyJ's Avatar
P.N. is C2C21115, 1536 pounds before tax and shipping
all this for a 1 mm play ...
Who knows if a used part won't behave same as mine ?
Old Jul 26, 2020 | 04:31 PM
MarkyUK's Avatar
At an eighth of the price new it's worth taking a gamble, even if it's as worn you have spare to play with/weld/file/fettle
Old Jul 27, 2020 | 12:21 AM
DannyJ's Avatar
At an eight of the price new it's worth taking a gamble, even if it's as worn you have spare to play with/weld/file/fettle
Exactly this and that's just what I am going to do
baloozman
Dec 31, 2021 11:40 AM
mherwald
E type ( XK-E )
Feb 22, 2020 09:44 AM
AL NZ
Mar 29, 2015 04:12 AM
andypreston
E type ( XK-E )
Nov 28, 2014 07:52 PM
Jaggyx
Dec 24, 2008 08:01 AM
