please help identify an engine part
Old Apr 3, 2023 | 11:58 AM
racerxf12004's Avatar
Default please help identify an engine part
2013 xkr. Guys i got an oil leak from this part that is bolted to the front side of the upper engine oil sump and i have searched high and low to find out what it is? The part number rubbed off it. Also surprised to find out that there is no gasket between the lower and upper oil pan...its just bolted directly together.
Old Apr 3, 2023 | 02:56 PM
RichardS's Avatar
I've no idea what it is as there's nothing like it on the XK that I can recall.
However, as it's fixed to the oil sump, it must surely be a level sensor, a temperature sensor, a pressure sensor, a pump, a filter or a heater.
Admittedly, it doesn't really look like any of those but what else could it be? 🤔
Richard
Old Apr 3, 2023 | 03:59 PM
sicarumba's Avatar
Looking at page 77 of this manual it looks to be something to do with the fuel cam timing?
Old Apr 4, 2023 | 03:40 AM
RichardS's Avatar
That's definitely the part in question. It appears that it can be removed and a new gasket fitted but be very careful not to turn the engine whilst it is removed or it looks as if you will have to buy the special tool to re-fit it.
Richard
Old Apr 4, 2023 | 04:15 AM
OzXFR's Avatar
It's the oil vacuum pump which is a fairly common oil leak point on the AJ133 (and I guess the AJ126), see this recent nearby post and especially the link inside it: https://www.jaguarforums.com/forum/f...1/#post2629500
Old Apr 10, 2023 | 11:27 AM
yes, your right, OzXFR... it is the oil vacuum pump and there is a rubber seal/gasket that i will replace on it after I drain and change the oil.
I will post an update in a few weeks if this solved my oil leak.
Old Apr 10, 2023 | 01:09 PM
jahummer's Avatar
I rebuilt mine quite easily with new seals.
ExcelsiorZ
Sep 14, 2024 08:57 AM
speeedracer
Sep 2, 2020 08:59 AM
stillka
Nov 2, 2015 11:16 PM
David7
May 19, 2015 08:32 AM
daboss085
Aug 31, 2013 06:35 PM
