Power Window problem
Old Mar 25, 2016 | 07:55 AM
jantech's Avatar
Default Power Window problem
My windows do not go down the 1/2 inch when I open the door. Is this a common problem, is there a fix I can do myself?
Thank you!
Old Mar 25, 2016 | 08:13 AM
WhiteXKR's Avatar
Try to reset the windows as follows:
Turn on the ignition. Start with the windows up and doors closed. Lower both windows and keep holding the buttons for 5 seconds after the windows are down. Then raise the windows and keep holding the buttons for 5 seconds after the windows are up.
If the problem resolves, then recurs again, your battery is probably low and needs a charge or replacement.
Old Mar 25, 2016 | 11:26 AM
jantech's Avatar
Default Resolved!
Thank you WhiteXKR! That was easy, problem resolved.
Eel
Apr 29, 2016 08:12 AM
jmbpharris
Mar 30, 2016 08:07 PM
JimC64
Mar 29, 2016 09:50 AM
KitKel
Mar 24, 2016 10:19 PM
EscapedApe
Mar 19, 2016 01:28 PM
