Question about Topix
Old Feb 22, 2023 | 01:31 PM
McJag222's Avatar
Default Question about Topix
Having issues with a Jag dealer getting quotes for parts/service for valley hoses replacement. My question is will access to Topix give me more detail for the procedure than the service manuals listed in
the stickies thread - does Topix have a more thorough breakdown of the job?
Old Feb 22, 2023 | 02:49 PM
TOPIx will only give you the same procedures as the Workshop Manuals in the 'stickies' - that's where they came from.
JLR used to publish 'labour times' for tasks but I haven't found these recently. I expect with something like valley hose replacement, a Jaguar Dealer really doesn't want the aggravation and will give an outrageous quote either to put you off or to make a handsome profit if you decide to proceed.
Old Feb 22, 2023 | 03:03 PM
McJag222's Avatar
Thanks Graham, I thought the sticky manuals came from the Topix. I'm having trouble getting the dealer to source seals and gaskets in the quote, they included the outlet pipe #AJ812469 (houses the thermostat) at $1100 - not needed - I'm working through the EPC to find parts currently. There has been some kind of "shake up" at the dealership - service manager no longer has access to parts catalogue, passed the job onto the parts guy. Place seems to have gone downhill since the last time I had some major service done.
Old Feb 22, 2023 | 03:15 PM
Cee Jay's Avatar
I had an indie Euro shop do my hoses on my XKR. Other stuff also, like SC torsion isolator, changed S/C oil, GDI injectors on the remaining side, oil cooler replacement (that's what leaked, I thought it was the coolant lines. Nope. Did 'em anyway),
Coolant flush, several times to rid ALL moisture and a replacement with EVANS waterless. Swapped out the thermostat, checked the water pump (perfect Original) changed the belts, and a couple other minor things. All-in was like $5200, but now it's done.
Old Feb 22, 2023 | 03:27 PM
McJag222's Avatar
Parts so far from the new quote - some parts (gaskets and seals) not on there - $1100 when the not needed outlet pipe is subtracted, I emailed and asked what about the labour charge?
Old Feb 22, 2023 | 03:43 PM
Brewtech's Avatar
The dealer is not your friend in this. Go to an Indy who knows XK cars. Even a Rover guy knows your engine quite well.
Old Feb 22, 2023 | 03:45 PM
Cee Jay's Avatar
What he ^^^^ said. The labor for Jaguar is I think $225 or more now per hour. The job total hours is somewhere around 20 hours, so that's another $5k or so. Just an estimate, but probably close.
Old Feb 22, 2023 | 03:58 PM
McJag222's Avatar
I don't think they are that high Cee Jay. Previous quote for labour was $1830.95 Canuck dollars, but I think they underestimated the scope of the job. I'm using the parts list from this guys thread as a guide - it's a good write up:
Originally Posted by gkubrak
For anyone interested, here is a part list and some guiding steps for the job.
O-rings for vacuum and breather lines are not on there. As well as cleaning cans, masking, paint, misc tools, etc...
Old Feb 22, 2023 | 04:04 PM
McJag222's Avatar
In the past they've been good, couple of older mechanics. I think they might have retired so experience is lost.
Old Feb 24, 2023 | 06:34 AM
guy's Avatar
guy
@McJag222 , I’m in Ottawa. Shore Auto did the work for me at about 5k. And that included maintenance on the supercharger as it was off, anyways. (and every time she visits the spa, she gets an oil change and massage) As others have said, find yourself an Inde that knows jags and LRs. Being in Vancouver, there must be a few.
Old Feb 25, 2023 | 09:34 AM
djhaydel's Avatar
Had the valley hose replaced on my 2013 in 2021 and it was $1179 The intake manifold gasket were over priced and I challenged them but i think they were covering actual manhours,
Valley hose replacement
Old Feb 25, 2023 | 11:56 AM
McJag222's Avatar
The job for the XKR is more complicated.
Jjdejd
XE ( X760 )
Sep 14, 2023 07:18 PM
sksahai
XF (X260)
Sep 13, 2022 04:56 AM
Speedmaster
Jun 27, 2021 05:44 PM
Clifsmith
Sep 5, 2009 09:34 AM
