Question on lug nuts for 2007 XK w/ 19" wheels
Old Sep 22, 2012 | 03:02 PM
pabanker's Avatar
Default Question on lug nuts for 2007 XK w/ 19" wheels
Hi all. I am useless mechanically and do not wish to try taking a lug nut off the 19" OEM wheels of my '07 XK. I need to order replacements (4, one for each wheel) for the locking nuts the previous owner put on but lost the key to. Can someone tell me what "seat" I need to order: acorn/cone, mag, or ball? Does it matter? Anything else I should know or consider? Thanks!
Old Sep 22, 2012 | 04:29 PM
abonano's Avatar
If you have the OEM alloy rims you should be ordering the mag lug w/ washer.
Here is an example I came across:
locking lug nut set / c2c9198 | eBay
The lug nut size is M12 X 1.5 - for a good cheaper option look into the McGard Wheel locks - they make a OES equivelant set for the Jaguar vehicles w/ the intergrated metal washer - I use them on my alloy rims with no issues. Hope this info helps.
Old Sep 22, 2012 | 07:39 PM
pabanker's Avatar
Thanks so much, but my post was not clear. I don't want to replace them with new locking nuts, I want to replace them with regular (non-locking) nuts. Can I use any type of M12x1.5 nut with my 19" OEM alloy wheels? Or must I use a mag lug w/ washer?
Old Sep 22, 2012 | 07:55 PM
pabanker's Avatar
Hey hey! Finally found someone who sells the OEMs! I guess that'll do.... Should be cheaper than buying them through a dealership, no?
2007-2012 Jaguar XK Lug Nut - Original Equipment - Auto Parts and Accessories - Shopping.com
Old Sep 22, 2012 | 09:57 PM
abonano's Avatar
Yes, much cheaper! That's exactly what you need pabanker...
sadepol01
16
Nov 22, 2024 05:05 PM
Johnken
Apr 8, 2018 10:21 AM
MrWhite
33
Oct 22, 2015 10:29 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
