Radio activation code
Old Dec 1, 2016 | 05:10 AM
JonWat's Avatar
Default Radio activation code
Hi,
Having just upgraded from a 2004 XKR to a 2008 XKR & checking through all the paperwork & documents I suddenly realised I have no code to reactivate the radio after battery disconnection as I did with my previous X100.
I can find no mention of it in the handbook so do I need one in the UK, if so how do I go about getting it.
Thanks for your assistance.
Old Dec 1, 2016 | 05:52 AM
Mine doesn't have one. Jaguar have finally stopped this stupidity with European specification vehicles.
Old Dec 1, 2016 | 06:20 AM
jimbov8's Avatar
With the infotainment system you don't need a code.
Old Dec 1, 2016 | 12:03 PM
Cee Jay's Avatar
Quite right. The code was only there to deter theft. With these cars theft isn't a likelihood. Or really even possible without taking the whole car.
Old Jul 16, 2023 | 04:25 PM
My First Jaguar's Avatar
Default Radio Code - 2011 Jaguar XK Convertible
Can someone please confirm whether or not a 2011 Jaguar XK Convertible has a radio code?
Old Jul 16, 2023 | 04:31 PM
RichardS's Avatar
None of the X150 models use Keycode radios.
Richard
Old Jul 16, 2023 | 04:48 PM
Cee Jay's Avatar
Richard
ACTUALLY, isn't the .... I'm guessing here, the TSD is the display FOR the 'radio', but isn't it controlled by something else? Wouldn't that 'sound module' or whatever have a VIN in the firmware? I don't know, so I ask. Course if the TSD actually IS the sound system, I guess there isn't any code. I've never thought about it before.
Old Jul 17, 2023 | 01:53 AM
RichardS's Avatar
I am sure that if a new radio/display were installed it would have to be coded to the car using suitable ODB software. However, there is no radio code so the existing unit can be removed and reinstalled without knowledge of any code, unlike a keycode radio.
Richard
Old Jul 17, 2023 | 03:28 AM
I thought I'd made it clear in post #2 seven years ago but I'll repeat that the X150 audio system does NOT have a radio security code for owner input after a battery disconnect/reconnect.
Any consideration of programming replacement components for compatabilty is a completely different topic not relevant to the theft deterrent purpose of radio security codes.
Old Jul 17, 2023 | 10:53 AM
I remember seeing your previous post about the X150. I wasn’t aware the X150 and the XK were the same. That is why I asked my question specific to the XK. My mistake. Although I didn’t mention it in my question, I wasn’t concerned about needing a radio code in the event of radio replacement or theft. That's a different topic.
I was concerned about needing a radio code in the case of power interruption when replacing the battery.
I am planning on using a NOCO Genius 10 in 12v supply mode (not charge mode) to supply power to the car during the battery change. Either that or I will use another battery to power the car.
Thank you for the clarification.
Old Jul 18, 2023 | 05:37 AM
I remember seeing your previous post about the X150. I wasn’t aware the X150 and the XK were the same. That is why I asked my question specific to the XK. ......
Worth a slight diversion from the topic to explain this model naming convention.
X150 is the Factory Code for the 2006-2014 XK model.
We use the Factory Codes on the forum to distinguish between similar named models. For example, XKR could be the earlier steel bodied 1996-2006 XKR (Factory Code X100) or the later aluminium bodied 2006-2014 XKR model.
The XJ badge is even more confusing with five different models produced between 1968 and 2019!
Old Jul 18, 2023 | 06:29 AM
Thank you for the explanation. Now I know.
ericthexjs
Aug 3, 2023 08:35 PM
Markmbaha1
Sep 8, 2021 08:39 AM
TropicCat
Jul 13, 2021 10:51 AM
KASSER
Oct 29, 2019 12:25 PM
ziondio
Sep 28, 2015 11:24 AM
