Rear fender molding installation
Old Feb 10, 2019 | 05:26 PM
Tp10XKR's Avatar
Default Rear quarter molding installation, OEM flares !
I ordered the rear quarter moldings c2p5094, c2p5095 and clips c2p5091(12).
Im looking for the directions for the installation, where they clip in and tape on. Anyone have the factory directions ? Or some good photos of thiers installed ?
Tom
Old Feb 12, 2019 | 05:23 AM
scm's Avatar
scm
When I got my front centre spoiler it came with comprehensive installation instructions, hopefully yours will be supplied too.
Old Feb 12, 2019 | 07:43 AM
pwpacp's Avatar
Unfortunately mine didn't come with good instructions but I found it not hard to figure out exactly how/where to place them.
There are small dimples that fit in the seam where the plastic bumper meets the metal rear quarter. I first cleaned the entire mating surface where they mount, first with soap & water, dired it, and, finally used rubbing alchohol. Then I mounted each to the rear 1st with the clips followed by pulling the 3M tape cover and pressing it into position on the forward section.
As to how the clips go on: they are spring steel so they can not contact the aluminum body parts so it has tabs that fold over to sandwich the sheet metal edge. Once folded over the clip can then be pushed over the sandwich. You'll find that rather hard to do since they won't slide on easily. I used a pair of channel lock pliers to seat each clip using a soft but thick shop rag on the outside to protect the paint. Make sure not to use too much force as the composite material of the moldings can be crushed.
Also, though the 3M tape is there to hold it in place there is a clip at the forward most point too. As I remember, the clips have the front lip bent up to help guide it and that side needs to be "up" toward the inside of the body. If it is reversed you'll likely catch your hand on it when washing the car in that area....learned from experience.
Old Feb 12, 2019 | 09:53 AM
Tp10XKR's Avatar
This is just another example of why these forums are so important to all of us. Thank you for the replies I will install tonight if all goes well. No direction in the box, my body shop guy has no info and he called the dealership who told him they have no directions to provide either( shady) they are just keeping the info for themselves.
If you have a minute can you attach a pic or two of yours installed to go along with your great detailed description.
Old Feb 12, 2019 | 01:14 PM
Those P/N's are the Rear Wheelarch Spats?
If so, here's my RH viewed looking towards the rear of the vehicle and with the liner removed.
Old Feb 12, 2019 | 01:53 PM
Tp10XKR's Avatar
Yes Sir, rear wheel “spats” as you refer to them. Thanks for the photo !
Old Feb 12, 2019 | 02:47 PM
I can't claim invention of the description. They are termed "wheelarch spats" in JEPC:
There doesn't look to much working room to attach the clips without removing the liner.
Old Feb 12, 2019 | 03:45 PM
pwpacp's Avatar
+1, were I to replace mine again both the wheel and liners would come out to make "tapping" them in place easier!
Old Feb 15, 2019 | 09:37 AM
Tp10XKR's Avatar
Default Closed
Today, I finally installed the rear wheel well spats, so easy a caveman can do it!
Their is two tabs on the forward part of the spat that once on the lip fold over into recessed pockets on the inner quarter panel. I lined them up and folded them into the pocket, then pulled the tape covering off and stuck it to the lip. Once that is done I started at the top and installed the six clips down to the bottom. The clips have no problem going over the folded over tabs. I was able to put them all on by hand, but I did go back with a small mallet and tapped them flush. No need to remove inner fender liner. In fact, if it wasn’t for cleaning and putting another coat of F11 on the wheel barrels I didn’t need to pull the wheels.
Old Feb 15, 2019 | 11:08 AM
pwpacp's Avatar
That looks really great! It is a detail that should have been included on the XK models not just the XKR, IMHO!
Now think spring so you can really get out and enjoy!
Old Feb 15, 2019 | 01:12 PM
kj07xk's Avatar
Like the way they look, so I searched online for them. What some of those online Jag dealers want for shipping is just nuts!
Their parts total comes to like $90, and then they want $90 - $128 just for shipping!!!
Went to SNG Barratt, $88 for parts, and only $12 for shipping. They got my order.
Old Feb 15, 2019 | 01:44 PM
Tp10XKR's Avatar
thats where I ordered mine, best price I could find anywhere. They took about 10 days to arrive from Barrett but the weather here was bad and they were waiting on a shipment from across the pond.
Best of luck to you Sir,
Old Feb 15, 2019 | 01:58 PM
110reef's Avatar
They look great! Good work!
coldpad1
Apr 3, 2017 03:24 PM
Shane7
Jul 10, 2015 01:30 AM
tom11011
Oct 30, 2012 04:01 PM
Jsedita74
May 9, 2011 02:44 AM
