Rear luggage cover
Old Sep 16, 2015 | 07:35 AM
SeanU's Avatar
Default Rear luggage cover
I'm almost straightened out with my "new" 2011. Last issue is the detachable luggage cover. The car came with one missing rear clip. I ordered 2 from Gaudin. No matter what I did, the clips wouldn't hold for more than 1 or 2 trunk opens. The last time, the cover came off as I was closing, and broke the clip I replaced. I still have the extra one I ordered.
I'm taking it to the dealer tomorrow for my last warranty service, will try to get them to fix under warranty. If they don't, I'll need to do it myself. I am thinking of getting some rare earth magnets and doing some slight modding. Anyone try this or other ideas? Seems like a pretty bad original design.
Old Sep 16, 2015 | 10:47 AM
britannia's Avatar
Smile
My cover is holding fine (07) after I fiddled with them; but you are right very poor design (sort of thing the Guys across the channel like to do).
Button magnets is the way to go................... I've used them on my gas fireplace door; work every time.
Good Luck, Adrian
Old Sep 16, 2015 | 03:08 PM
AlexSaltLife's Avatar
SeanU,
I have the same problem as well, on my 2011 XKR. I should do something about it. But I just don't open my trunk that often so I tend to forget.
Old Sep 16, 2015 | 03:47 PM
tampamark's Avatar
Would you have a picture of the rear luggage cover? Is that an extra item in the trunk? All I see in my back trunk the convertible top separator.
Old Sep 16, 2015 | 04:36 PM
ralphwg's Avatar
They are talking about coupes. The convertible does not have a luggage cover per se, just the separator for top stowage.
Old Sep 16, 2015 | 04:48 PM
tampamark's Avatar
Thanks Ralph!
Old Sep 16, 2015 | 11:35 PM
tberg's Avatar
I had the same problem where it wouldn't stay attached more than one or two times when closing the trunk. I found that the clips actually unscrew a bit ( the part that plugs into the hole) when you turn them, and this extends them into the cavity a bit more when the clip is pushed down. There is then more expansion behind the hole and it will grab much more securely. Ever since I did that about 8 months ago, I've had virtually no problems.
Old Sep 17, 2015 | 03:24 AM
Originally Posted by SeanU
.......... No matter what I did, the clips wouldn't hold for more than 1 or 2 trunk opens. The last time, the cover came off as I was closing, and broke the clip I replaced. I still have the extra one I ordered. ..........
Mine was doing the same.
The clips were OK - it was the rubber inserts (arrowed in red) in the tailgate holding the cover locating pins that wear. This releases the tension holding the clips into their rubber inserts and the cover drops down.
I replaced the four rubber inserts and two clips and have had no repeat of the issue in over a year.
Old Sep 17, 2015 | 06:40 AM
DGL's Avatar
DGL
I cleaned my back window the other day and removed the cover to get access to the window inside. When reinstalling the cover I noticed the rubber inserts would push in when inserting the cover tabs. If the rubber inserts are not completely covering the tabs when tabs are inserted the holding strength will be compromised. I wetted the rubber tabs with water to reduce the friction when inserting the tabs so they would slide in easier. When the water dries shortly after installing the cover there should be sufficient grip to hold the cover in place. This could be part of the problem--the rubber inserts need to fully hold the tabs and not be pushed in when re-installing. I agree this is a poor design.
Old Sep 18, 2015 | 01:16 PM
RobB's Avatar
I just wrapped cohesive tape around and pushed them back in. Worked fine, never comes off and no rattles!
Old Mar 16, 2021 | 04:27 PM
Redlanner's Avatar
Default Rear Luggage Cover Latches?
I have a 2011 XKR coupe, and the luggage cover latches (and the pins at the rear of the cover) are looking and acting sketchy. Does anyone know where you can buy replacements?
Old Mar 16, 2021 | 10:59 PM
peterv8's Avatar
Have you tried a dealer?
Old Mar 17, 2021 | 11:35 AM
Tracee's Avatar
I got my replacement latch from S.N.G Barrett part C2P19092, which is the upper latch. Search their site for the "lower" locks you need.
There is a thread here which I found helpful:
https://www.jaguarforums.com/forum/x...r-broke-66831/
Old Mar 17, 2021 | 01:16 PM
Redlanner's Avatar
Thank you, Tracee! I searched for hours yesterday, trying to find these latches - or any reference to the luggage cover and the fasteners it requires. Can you tell me what category Barratt (or Jaguar, for that matter) places this assembly under?
Old Mar 17, 2021 | 01:19 PM
mosesbotbol's Avatar
Aston use magnets all over the car and I think for the rear luggage shelf too.
Old Mar 17, 2021 | 07:29 PM
Tracee's Avatar
Redlanner: I also spent hours poring through Barretts catalogue as you did, and getting nowhere. I finally got the number for the part I needed only from the posting sent above. So don't know what category it'd fall under. Numbing with how many thousands of bits to into our cars...
Old Mar 17, 2021 | 09:09 PM
Redlanner's Avatar
It's incredibly mind-numbing! I had been searching for cargo or luggage cover or screen bits. But it's not called a cargo or luggage cover or screen. It's called a
"Rear Parcel Shelf - Tilting." Of course it is. Despite the fact that it's not a "shelf" in any sense that we'd imagine - or at least a shelf that you would or could put anything on. Anyway, once you know what it's called, you can find those bits anywhere! Thanks for your help, Tracee.
Old Mar 17, 2021 | 10:38 PM
ralphwg's Avatar
Aahh - English as a foreign language!!
LovingIt
Jul 19, 2016 01:21 AM
tberg
Oct 11, 2013 04:37 PM
Padrino
Jul 18, 2013 10:36 PM
