Replacement Front brake Pads/Rotors
I need new front brake pads/rotors. I took my car to local repair facility and they ordered OEM parts from the local Jaguar dealer. Two weeks later they still don't have the parts, the Jag dealer says parts are scarce. So I've done some on-line snooping and I find I can get NAPA pads/rotors for about $527.
Has anyone here used them - any comments.
Tom
Tom
I have just replaced all four rotors with the premium Napa rotors. They are a vented rotor(in this case they have a swirling grove on the rotor face. They are made of a rust proof alloy and they look awesome. I had to go to Bumper to Bumper for the pads. For all I know the pads could very well be what I would buy at the Jag dealer. While you are at it you could paint the calipers. I would send you a photo but am having some issues with inserting it into this reply.
Be kind to your rotors!
My 2009 XKR Portfolio just turned 30K miles, and the dealer recommended replacing the front pads since they were getting low. Rears were still OK. Because my car has the optional Alcon brakes with 6-piston front calipers and 400mm (15.75") rotors, I decided to have work done by the dealer to avoid potential problems. The technician inspected the crescent-drilled rotors, said they still looked good and advised against turning them. I was a little leery about them possibly pulling, but they didn't. One note - I really babied the brakes for the first 100 or so miles to get the new pads to properly seat into the "old" rotors. Not having to replace the rotors saved $978 ($489 per rotor @ msrp)! Ouch!
Lesson learned: replace your brake pads before they score your rotors and save $$. If you don't have to turn the rotors, they'll resist warping (since they're thicker) and last longer before you have to replace the pads again.
I don't understand why your dealership says parts are scarce. I certainly haven't found that to be true. I had rear rotors/pads and front pads replaced in one day recently. HOWEVER, I got price quote from private shop and dealer matched them, plus 15% of for being local Jag Club member. No complaints here...
That's their story.
Tom
Regarding NAPA rotors... I've always considered any parts store brand to be what you use when you're about to sell the car. Either go OEM, or go name brand. For instance... EBC makes rotors that meet OEM specs and will be ofuch higher quality a metal than NAPA for less than half the cost of OEM...
https://thmotorsports.com/ebc-brakes/ebc-brake-rotors-premium-oe-style/rk1788/i-1996659.aspx
BrentGardner
28
04-26-2024 03:08 AM
philwarner
12-06-2021 07:13 AM
Doberman_Fan
22
12-24-2019 06:21 AM
Fraser Mitchell
10-01-2015 04:06 AM
