Restricted Performance message
Old Jan 11, 2016 | 07:47 PM
texasxkr's Avatar
Default Restricted Performance message
While driving my 2013 XKR in the Blue Ridge mountains, I received a "Restricted Performance" error message, car lost power, when trying to apply power tach would rev to about 3000 RPM but car would hardly pull. Took car into Jaguar and they could not find a code stored. Anyone had a this problem or could shed any light on what might have caused this? TIA.
Old Jan 11, 2016 | 10:24 PM
tberg's Avatar
texasxkr,
I had it happen about 3 weeks ago. The first time it was momentary and I did not lose power. Second, third, and fourth times I lost power as well and the restricted performance warning stayed on much longer. It turned out to be the water pump for the supercharger was malfunctioning and when it does it protects the supercharger from overheating by keeping revs down and essentially turning off the supercharger. I had the supercharger water pump replaced and haven't had any repeats in the past 2 weeks.
Old Jan 12, 2016 | 02:21 AM
JagV8's Avatar
That's occasionally been reported as the fix for the STR, too.
(In effect the car sees IAT2 as hotter than expected so pulls timing etc - sometimes manages to flag a code but may take a few drives.)
Even a bad battery can cause RP. It's the car trying to allow continued use despite being in distress. It tries to flag codes but if enough things look weird or if the code(s) need (by law) 2 similar occurrences it struggles.
djhaydel
Jan 8, 2016 11:49 PM
johnlw100
Dec 20, 2015 07:20 AM
tberg
Dec 17, 2015 07:15 PM
davecabezo
Dec 16, 2015 08:28 PM
uncheel
Dec 15, 2015 06:37 PM
