Reverse lights
Old Dec 26, 2012 | 01:53 PM
Gmancuso's Avatar
Default Reverse lights
I'm reading conflicting threads. How many reverse lights are there on a 2009 XKR?
Old Dec 26, 2012 | 02:37 PM
SPiDi's Avatar
One
Old Dec 26, 2012 | 05:17 PM
Gmancuso's Avatar
Old Dec 26, 2012 | 09:35 PM
amcdonal86's Avatar
I thought is was only one for 2007 models and two for all others.
Old Dec 27, 2012 | 10:25 AM
Snide72's Avatar
Default One Back-Up Light, One LED Rear Fog Light
I just went through this on my 2009 XK two weeks ago. When I was told by a friend that my left back-up light wasn't working, I removed the left taillight unit in the trunk lid only to find that it was a "sealed" unit with no way to get inside to replace a bulb. I took it to my nearby Jag dealership where the Service Manager explained that my only back-up light was in the right taillight unit in the trunk lid. The the left taillight unit in the trunk lid contains an LED rear fog light that the owners manual says to use only during periods of fog. Since it is a sealed unit, if that LED bulb ever burns out, I assume you do have to replace the entire unit.
Old Dec 27, 2012 | 11:01 AM
britannia's Avatar
Maybe Not; sealed things can be unsealed! I am thinking of unsealing the fog light and hopefully replace bulb/led with a white one. This way I can have 2 backup lights (tired of being told " your back light is out!") Then when backing up turn on rear fog light! but will have to remember to turn it off because don't have front license plate............and don't want to attract attention from you know who!
Adrian
Old Dec 27, 2012 | 11:24 AM
Rey's Avatar
Rey
Seems to me that one could not only replace the color LED in the rear fog with a clear LED, but also connect the wiring to from the rear fog to the rear back up.
Obviously, you'd disconnect the wire running to the rear fog switch in so doing. Then wonder if you'd get a fault code? Maybe one should leave the fog wiring intact with color bulb, but remove the color bulb, leaving it to shine in some dark place, if at all. Then wire directly between the new clear bulb in the fog and the backup. What do you think?
Old Dec 27, 2012 | 02:02 PM
britannia's Avatar
Rey,
Sounds good except depends on bulb/LED holder and how will BUL circuit responds to extra wattage. Try it...................?
Adrian
Old Dec 27, 2012 | 02:41 PM
djgold's Avatar
Disconnectiong rear fog or backup light does NOT trigger fault codes. Only out bulbs with filaments trigger errors... Good luck though...
Old Dec 30, 2012 | 09:43 PM
britannia's Avatar
Do the UK (RHD) XK's have the reverse light on the Left? If so, another option would be to use one to replace the fog light! IF CORRECT WHAT IS THE PART NO FOR A UK UNIT? and at what cost?
And FYI new TATA leader is an Irishman!!
TTFN Begorahh, Adrian
Old Apr 14, 2017 | 05:18 AM
Rick7311's Avatar
You will need the lens off a 2010+ to do the swap, the rear fog has a circuit board with nowhere to plug a regular bulb in. You wont trigger any codes if you either tap into the wire harness & pick up the feed from the opposite light or splice in from the opposite light. The lense shouldnt cost too much.
Old Apr 18, 2017 | 09:44 PM
Firecat17's Avatar
Just curious as to why you'd want to remove and replace the rear fog light...
Old Apr 19, 2017 | 01:15 PM
Cee Jay's Avatar
The earlier tail lights 2006-2009 had only one reverse light and one fog light. Ugly, plus they used standard bulbs. The 2010+ tail lights have BOTH two fog and two reverse. Looks MUCH better plus they are all LED and no standard bulbs, a much crisper, newer look.
Old Apr 19, 2017 | 06:23 PM
Ian D's Avatar
It's also an expensive upgrade on the 4.2 just for two reverse/rear fog lights and led tail lights. They lights were changed on the 5.0L model.
In U.K. It's law to have a working rear fog light, doesn't matter about having a reverse light. Not sure about other countries laws though.
Old Apr 19, 2017 | 06:40 PM
Cee Jay's Avatar
No fogs in the old USA. I expected lights on the FRONT to come on with that switch, but there aren't any.
Old Apr 19, 2017 | 07:43 PM
Firecat17's Avatar
I guess Im more of a traditionalist. A single rear fog and backup light suits me just fine... and the lights look plenty fine as well.
Not sure what you are meaning by no fogs in the old USA.
Old Apr 19, 2017 | 07:46 PM
Cee Jay's Avatar
Fog lights are not required in the US, neither front nor rear.
Old Apr 19, 2017 | 08:01 PM
Firecat17's Avatar
Certainly, they're not required that I know of. But they are perfectly legal to use... both front and rear in most States, during weather conditions which will make the car more visible.
In my opinion, the Jaguar engineers did a great job in designing the placement of the single rear fog lamp and backup lamp, as well as the placement of the forward facing fog lamps.
In our part of the State, both of these are very nice to have during the Tule Fog laden Winter months.
FrickenJag
Jun 16, 2025 02:15 PM
Jpav27
Jul 31, 2022 06:43 AM
neruda
Oct 18, 2015 01:19 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
