Rumble/Vibration Only when pulling away
Old Apr 13, 2023 | 12:37 PM
Biggfish's Avatar
Default Rumble/Vibration Only when pulling away
Hi Everyone..........Have a 2010 XKR. When i pull away from a standing start i get a Rumble/Vibration. It seems to come from the rear.....but only up to about 10mph. Nothing through the other gears and she runs like a dream.....could it be the start of something.....She,s auto...Thanxs
Old Apr 13, 2023 | 03:49 PM
jahummer's Avatar
Drive shaft, differential or trans mount?
Old Apr 13, 2023 | 04:00 PM
RichardS's Avatar
Could also be a wheel bearing. Simple job to jack up each rear wheel in turn and give them a spin to check.
Richard
Old Apr 13, 2023 | 08:23 PM
Brewtech's Avatar
Loose exhaust? Will it do it with the car in Park and revving into the power band slowly?
Old Apr 13, 2023 | 08:52 PM
mhminnich's Avatar
One more vote for trans mount.
Old Apr 13, 2023 | 09:07 PM
tberg's Avatar
Are you sure it's just when pulling away and not when turning and pulling away. There has been discussions about "shuddering," a vibration at low speeds when turning. I have had it many, many times on my 2010 XKR, and changing differential fluid seemed to take it away. I haven't had it in a very long time now, and it used to be constant.
Old Apr 13, 2023 | 10:49 PM
ralphwg's Avatar
What Ted said, particularly when the XKR hasn't warmed up. Service people tell me that that is what causes the shudder and not to be concerned about it.
Old Apr 14, 2023 | 11:55 AM
Firm's Avatar
This is what I was going to post as well. Sounds like a common issue, I had it with mine as well until I changed the differential fluid.
zman112233
Aug 4, 2019 07:00 AM
Chapperz
Feb 4, 2019 05:08 PM
Ironheadvette
Jan 27, 2015 01:00 AM
