SDD problem
Old Nov 11, 2021 | 08:58 AM
Sovejag13190's Avatar
Default SDD problem
Hi i've problem on my Jaguar XKR 2007. I can't use SDD because it can't read my VIN number automatically and when i try manual VIN it say that VIN it's not correct. one month ago i use SDD and it's ok and now i can't use it. I've SDD 158 and VCM jaguar (Ford). The VCM is detect by pc.
The VCM have lignt on, but i don't understand what's the problem.
Is there possible have a problem on odb connector ? I try to use autoenginuity and it can't connect to my car.
Thank's for all.
Marc
Old Nov 11, 2021 | 09:37 PM
u102768's Avatar
Presumably none of the pins in the VCM connector are bent?
Old Nov 12, 2021 | 02:01 AM
Thank you for your answer. I don't know but i've control 12V on pin 16 and 4 or 5 and it's ok.
Today will control CAN BUS but i think it's ok because the car have no problem.
I go to control connector ODB. it's common problem ?
Marc
Old Nov 12, 2021 | 04:28 AM
After control i've take tension values on CAN BUS, i've connect the cable on odb connector :
And i control on the connector VCM :
Low CAN/Ground = 2.15 V and High CAN/Ground = 2.70 V
I've control resistance between low and high CAN and i've 62 ohm.
These values are good for me.
I try to use ELM327 and it's impossible connect to ECU.
I don't understand what's the real problem.
Thank's
Old Nov 12, 2021 | 04:49 AM
Other question : if i reset ECU can i have good connexion CAN after ?
Thank's
I've reset with battery negative cable on the battery postitive cable during 5 minutes.
I can read ECU with ELM327 and Torque on the phone but i can't connect VCM or autoenginuity.
I think that ELM327 don't have need protocol to access ECU but VCM or Autoenginuity read protocole and my car don't give the protocole.
Have you idea ?
Marc
Old Nov 13, 2021 | 03:45 AM
Hi i've test my HS (high speed) CAN but i don't test the MS (middle speed) CAN on pin 3 and 11.
And i've the good tension (2.7V on MS CAN + and 2.18V on MS CAN -) BUT i have no resistor !!! i should have 60 ohm and i've infini resistor !!
On the wiring there are two resistors 120 ohm (one in the instrument group and one in the BRA (auxiliary)). I don't thing that the two resistors are OUT. What do you mind about this problem ?
If i've a pin deconnected on the ODB connector i don't have tension non ?
Old Nov 13, 2021 | 06:57 AM
hi i've test MS CAN and it's ok. To have 60 ohms i need deconnect battery.
I've no pin déconnected on the OBD connector.
I don't understand why i can't read my VIN
I've try reset with battery negative on the battery positive and i wait 1/2 hour, wait and see !
Here pins VCM IDS Cable :
Old Nov 13, 2021 | 10:56 AM
After reset with battery i've the same problem.
I've trying with IDS 118 on the xp virtuabox and i can have informations about DTC and all modules on my car !!
I don't understand why with SDD it's not possible.
Old Nov 13, 2021 | 12:55 PM
xalty's Avatar
why would you even want to use SDD it sucks
get rid of the vm use a real laptop with ids v118 installed no more problems
Old Nov 14, 2021 | 01:30 AM
Yes exactly IDS v118 is better than SDD. But i don't understand why SDD don't read and don"t connect to my car.
Old Nov 14, 2021 | 10:20 AM
Sean W's Avatar
That tells me you have a software glitch in SDD. If it worked before, reload the software or stick with IDS as Xalty suggests.
Old Nov 14, 2021 | 11:48 AM
Thank's for answer.
Yes i think it's a problem with new SDD (159) is not compatible with my old VCM. Before i used SDD 157 and i've no problem.
I've trying to reinstall SDD 157.
And yes i do to use IDS now .
frankc
General Tech Help
Oct 25, 2024 04:53 AM
Aarcuda
Apr 3, 2020 02:59 PM
Sean W
Apr 6, 2018 09:17 AM
reyesl
Jun 6, 2017 01:23 AM
