Seat belt warning while buckled - 2007 XKR
Old Jan 20, 2018 | 07:33 AM
mkmccoy's Avatar
Default Seat belt warning while buckled - 2007 XKR
Had the convertible out yesterday for a bit (recent move to Missouri necessitated a trip to the service station for an inspection so I can get MO plates) and noticed seat belt warning would not stop, even though I was buckled up. I had a file on the passenger seat (weighed about a pound), moved that off - no luck. Unbuckled and re-buckled my belt a few times - no luck.
Any advice? Thanks - Mike
Old Jan 20, 2018 | 08:37 AM
Stuart S's Avatar
A low battery can cause all sorts of electrical glitches. Do you keep it on a battery maintainer?
Old Jan 20, 2018 | 08:47 AM
mkmccoy's Avatar
Stuart: Yes - it is on CTek at all times when not in use. Mike
Old Jan 20, 2018 | 10:43 AM
Sean W's Avatar
I assume nothing's in the back seat and your front driver's seat isn't applying downward pressure on the backseat. I would try bucking all seats first to see if you can isolate. If the light doesn't go out, you'll want to get the DTC codes.
electricboogaloo
Mar 8, 2021 02:31 PM
sktslls
Sep 18, 2020 10:03 PM
Patrick Wong
Mar 8, 2020 01:39 PM
2000blackxkr
Sep 13, 2009 10:28 PM
