Short cut to oil level check 5.0L
Old Sep 2, 2016 | 08:19 AM
jagtoes's Avatar
Default Short cut to oil level check 5.0L
I was just paging through the shop manual and reading the oil change procedure it describes how to check the oil after a refill. It said to press the start (no brake) and press the stalk to the oil level screen and then press the cruise control cancel button twice within 2 seconds. Go back to the stalk and press until the oil level comes up. I haven't tried it yet but will next time out.
Old Sep 2, 2016 | 10:13 AM
tampamark's Avatar
Like usual good info.
Some of these "hidden" procedures crack me up, surprised it doesn't say to open the door, get out and jump on one foot while rubbing your head in a circle with your left hand.
Old Sep 2, 2016 | 02:07 PM
axr6's Avatar
Those can drive me up the wall!!! Like the Service Required message reset; don't know how many times I tried it in both of my Jags without success. I even tried an ancient voodoo dance to appeal to the spirits of Jaguars...
A simple menu choice would be so much better but, who knows how the strange engineers at Jaguar sometimes think...?
Old Sep 2, 2016 | 02:55 PM
tampamark's Avatar
Exactly, couldn't just hold a button for 10 seconds, get a menu, scroll choices with steering wheel radio or cruise button. Engineers were laughing when they thought these up.
Old Sep 2, 2016 | 04:17 PM
jagtoes's Avatar
Remember the old ALDL codes flashing on the check engine light. Then came OBDI and finally OBDII
Old Sep 2, 2016 | 06:01 PM
tampamark's Avatar
Ha, that is true, my wife's old Mazda you had to stick a light into the fuse box in engine compartment to get blink codes.
Old Sep 3, 2016 | 09:31 AM
jhdee's Avatar
I think the procedure you have quoted is for calibrating/re-setting the oil level measuring system - done when a known quantity of oil has been put in the engine (no dipstick on the 5.0l !!!!).
I'm only guessing - but if you use this access method, if the oil level is down - it will just re-set and make the oil check indicator read full - a situation you don't really want.
Accessing the oil level check is shorter - press start, no foot on brake (i.e. ignition on) and then press the stalk control until the oil check screen appears.
Old Sep 3, 2016 | 11:22 AM
jagtoes's Avatar
Some have said that it takes them 10-20 minutes before the e-gauge even works while others have said it doesn't work at all or the do the check in the morning prior to start up. I use the OM method as you described and it takes me maybe 5 minutes or more. The service manual didn't state that this was a reset but a way to get a measurement within the normal method.
Old Sep 3, 2016 | 01:48 PM
jhdee's Avatar
When I check the oil level on my 2010, I normally do it before the first start of the day and then the oil level comes up immediately. There is only a delay if the engine has been running and I've been advised that the delay is necessary to allow the system & oil level to settle after running.
Would be good to confirm what the shop manual actually does - measure only or calibrate the system - could be very important as the 5.0 is quite fussy about its oils.
Old Sep 3, 2016 | 02:49 PM
jagtoes's Avatar
OK I just read through the total procedure for drain and fill of both the XK and XKR 5.0L engine. The procedure I described in my above post is NOT a calibration method but an engine oil check based on drain and refill. It does tell you to run the engine for 10 minutes after fill and then shut down for 10 minutes before you do the check . It does tell you to use the CC cancel button to get a reading if it does not come up on the info panel.
Old Sep 3, 2016 | 03:29 PM
tampamark's Avatar
In the 5.0 service manual there is a reference to resetting the average oil level, it is as follow directly from the book:
NOTE: The following steps are to update the average oil level value.
 Turn the ignition on.
 Press and hold the cruise control cancel button for more than 2 seconds.
The message center display will revert to the normal display in the trip computer.
17. Turn the ignition off.
18. Turn the ignition on.
19.
 Scroll through the trip menu to access the engine oil level display.
 Make sure that the average oil level value has now been updated.
Old Feb 2, 2021 | 04:33 PM
Tim Haines's Avatar
No, it won’t, all the shortcut to getting a reading from the oil level sensor does, is allow you to avoid having to warm the engine up to quickly check the level. Especially useful after refilling on servicing, you never get all the old oil out, so no one can quantify the correct amount to put back in, it needs to be checked while refilling. (Jaguar specialist for 34 + years)
DPK
Apr 20, 2024 08:37 AM
DPK
F-Pace (X761) / C-X17
May 13, 2021 06:09 AM
vandyke50
XF (X260)
Oct 13, 2020 04:16 AM
carzaddict
Jul 29, 2018 04:39 PM
jagtoes
Oct 1, 2014 07:46 AM
