Side Marker Eliminated.....GOOD/Aston Martin Grill on a XKR.....BAAD!
Old Jul 21, 2011 | 10:16 AM
GhostriderXKR08's Avatar
Default Side Marker Eliminated.....GOOD/Aston Martin Grill on a XKR.....BAAD!
So I came across this pic and notice they eliminated the amber side marker inside the headlight. I know some people were trying to figure out how to remove it. Then I noticed the aston martin grill. Nothing wrong with the AM grill as I think it looks good but not on a Jag! Anyways....I emailed them to see how they removed the amber sidemarker inside the headlight.....hopefully they will reply back.
Old Jul 21, 2011 | 10:28 AM
Brutal's Avatar
Youre car is really looking badasss, and it sucks you cant get a stick in a jag
Old Jul 21, 2011 | 08:53 PM
rscultho's Avatar
Pure, raw, unadulterated ***** envy
Old Jul 22, 2011 | 02:15 AM
XKRacer's Avatar
Looks to me they have seperated the glass/plastic, as it looks like they have also painted the bezel and chrome effect inside the lamp..... I quite like that, stealth look which works well on a black XK
Have to agree about the front grill always a bad move when you take such a distinct characteristic such as the AM grill and put it on a completely different car, something I would never do!
Old Jul 22, 2011 | 03:12 AM
username001's Avatar
Really the grille... is too much. Love the rest of the car but Astons are Astons, Jags are Jags.
Cadillac's Avatar
A wanna be Aston ? In a sense yes but not that bad at all
They should redesign the headlamps as well
Old Jul 22, 2011 | 05:38 AM
joycesjag's Avatar
That is one sweet looking vehicle, and I think the AM grill looks very stunning.
As for the headlamps:
Remove the headlamp assembly from the vehicle, remove all rubber and light bulbs from unit, place in oven set at 200 degrees for 8 minutes, using oven mitts remove, begin prying where the clear lens meets the black casing, put back in oven for 4/5 minutes repeat until you are able to seperate into 2 pieces.
The oven loosens the sealant very nicely.
Old Jul 22, 2011 | 10:16 AM
Brutal....definitely Jaguar should offer an optional manual eventhough these days car makers are moving towards DCT/SCT over manual.
So I didn't get an reply email from them regarding how to remove the sidemarker. Looking at pics when I remove the headlights in the past....it looks like there are clips to hold the clear lense ot the headlight unit. Most likely if I remove the clips......the clear lense will pop out from the unit. I'll have to check it out when I remove the headlights next time. Thanks guys for the info!
Old Jul 22, 2011 | 12:32 PM
Maxximus's Avatar
Car still looks sexy...how low is it sitting btw?
Old Aug 13, 2011 | 02:51 PM
Jeffrey Brewer's Avatar
The clear lens will not "pop" off when clips are removed, the clips were installed to hold assembly together while adhesive cured. I have cut the seam on Viper and Ferrari to refinish the interior then glue back - have not tried on Jag yet, but I am considering a project on my XKR Portfolio, If I do will upload photos
Old Aug 14, 2011 | 02:05 AM
XKRacer's Avatar
I can definately confirm the clips do nothing apart from what Jeffrey has said, I did look myself some time ago as I was asked to make some new bezels up with LEDs in them for a DRL, I did a very similar thing on a DB9. The XK plastic cover is glued on well, the oven idea would be a good one, just don't over cook it
Old Aug 15, 2011 | 10:27 AM
That DB9's LED DRLs looks pretty nice XKRacer. Wonder if you can do something like that for the X150's as I like how it's integrated inside the headlight unit instead of the strip outside.
Jeffrey Brewer: Please do share DYI pics if you do take apart the headlight unit. Thanks!
Old Aug 16, 2011 | 03:56 AM
XKRacer's Avatar
If you can get one apart and send the bezel to me, I could do it no probs.
I do not have any X150 light units hanging around here to try it on
Quantico
Oct 13, 2015 10:34 PM
bigdhenderson
Sep 29, 2015 05:29 AM
danke
Sep 24, 2015 02:41 PM
doctordeuce
Sep 12, 2015 08:30 AM
1964Daimler
Sep 9, 2015 11:28 AM
