slow soft top
Old May 4, 2025 | 07:36 PM
fishbait1's Avatar
Default slow soft top
so my soft top unlatched ok but is slow to start retracting ( 10-15 seconds) but then folds back normally. when i raise it it is again slow to engage but does close and lock but it takes considerable time for the windows to raise. i would guess 20-30 seconds. is that normal or are the windows effected by possible problems with the hydraulics?
Old May 4, 2025 | 08:58 PM
Cee Jay's Avatar
Considerable time for the glass to be in motion, or a long pause before or after they begin to move?
Old May 4, 2025 | 09:14 PM
kj07xk's Avatar
How’s your battery health? Are you doing this with the engine running or not?
Mine will be slower with the engine off. Sometimes the passenger window will not close all the way, and then retract if I’m closing the top with the engine off.
Old May 4, 2025 | 10:38 PM
fishbait1's Avatar
a long pause before the windows start to go up. they then go up as they should. i put a trickle charger on the battery so i'll check it tomorrow.
Old May 5, 2025 | 07:40 PM
Stuart S's Avatar
Reset your windows and make sure that your battery is fully charged. Operate the top only when the engine is running. See Post #5 by WhiteXKR (a.k.a. Steve the Jag Wrangler), the Forum's convertible top guru.
https://www.jaguarforums.com/forum/x...007-xk-204628/
Steve is the inventor of what the factory forgot - Soft Top Remote Control with rear window controller. It's highly recommended by many Forum members (including me).
Jhninkin
Nov 20, 2021 09:13 AM
OldCoot
Oct 15, 2021 03:26 AM
jantech
Mar 25, 2016 11:26 AM
GvilleVDP
Oct 6, 2013 12:01 AM
donnic
Jan 26, 2009 01:34 PM
