Steering Wheel R&R
Old Oct 16, 2024 | 08:59 PM
Sean W's Avatar
Default Steering Wheel R&R
Hey guys, I'm about to R&R my steering wheel. Replacing with one from an XF. I haven't pulled a SW from car with a clock spring before (yep I'm that old). Looking at the manual, first thing I see that I need is this:
So I'll prolly have a few questions. The first one - is there an alternative to this tool you guys have used to hold the clock spring in place?
EDIT: I guess here is another tooll I need to remove the airbag: Help with an alternate to the Jaguar tool as well. I'probably be able to figure something out if it were a better illustration:
Thanks again. I'm just skittish when it comes to the airbag.
Old Oct 16, 2024 | 09:14 PM
McJag222's Avatar
Give it "time" somebody must know
Old Oct 17, 2024 | 10:35 AM
Sean W's Avatar
OK service tool 501-120 is just a 90 degree flathead screw driver so I'm fashioning one now. Watched a couple of you tube videos and as long as I don't twist or turn the clockk spring, I should be fine. Maybe I'll get on with it today.
Old Oct 17, 2024 | 10:54 AM
Coventry Foundation's Avatar
That is sort of a fair description but it does have a twist in it. Here are the two we have. Our 211-326 is out on loan. Hope this helps.
Old Oct 17, 2024 | 02:31 PM
Sean W's Avatar
It did help thank you. I fashioned one out of a small chisel and used a vice grip to turn it. Worked just fine. I'm happy with the result:
rorainey
Feb 10, 2023 01:52 PM
marvelouzone
Jul 6, 2020 07:20 AM
SeanPeterLynch
Jun 8, 2014 10:27 AM
joebit
Sep 25, 2013 07:28 AM
