Sunvisor
Old Feb 10, 2024 | 10:14 PM
drbill's Avatar
Default Sunvisor
Hello all,
My driver's sun visor does the dreaded "pop and sag." From reading previous posts on the matter, I thought some pictures of the procedure might be warranted.
First, remove the sunvisor: it's easy: just pop the plastic cover away and there is one #15 torx screw. Remove it, unclip the wire and it's much easier to work with out of the car.
Second, remove the mirror assembly. There are 4 clips... shown in pictures.
Third, clamp the clamshell together. There is a lot of force to overcome.
Fourth: plastic weld the clam shell. I have not yet done this. I'm thinking of using a stainless steel mesh to put across the span, then melting it into the plastic to strengthen the bond. I will use the flat end of the tip on my soldering iron to press into the mesh/plastic.
Any other ideas are welcome.
First pic: close-up of clamshell.. you can see the gap and the red and blue wires snaking in, second is close-up of the flat tab that the rounded clip from mirror snaps onto, third is close-up of the aforementioned clip and the final pic is the sun visor on the table for perspective.
Attached Thumbnails Sunvisor-img_4537.jpeg   Sunvisor-img_4540.jpeg   Sunvisor-img_4539.jpeg   Sunvisor-img_4538.jpeg   Sunvisor-img_4536.jpeg
Old Feb 17, 2024 | 10:37 AM
drbill's Avatar
Well, I must say the combination of JB Weld plastic epoxy and plastic welding did not hold. Putting a screw in is difficult without removing the fabric. I may need a professional trimmer to get it sorted properly. I noticed the fabric on the A pillars is sagging anyway….
Old Feb 17, 2024 | 06:34 PM
Tracee's Avatar
The mesh melted into the plastic (and J/B) might be stronger. I've been thinking of this scheme for mine.
Old Feb 18, 2024 | 12:08 PM
panthera999's Avatar
I used this with several c-clamps overnight. Cardboard between the fabric and the clamp. Still solid a couple of months later.
Good luck.
Old Feb 18, 2024 | 12:12 PM
guy's Avatar
guy
Good… its not just me. I have never had success with JB Weld. I have always had success with ( the more expensive ) 3M products.
michaelodonnell123
Aug 24, 2024 05:30 PM
worrasf
Apr 21, 2021 05:30 AM
Stamford
Jan 26, 2018 06:39 AM
Wild Bill
Dec 25, 2010 04:01 AM
