Supercharger Sensor Fault or not....
Old Jul 29, 2022 | 10:20 AM
Squire's Avatar
Default Supercharger Sensor Fault or not....
Hi guys,
Recently my 2007 XKR started to run a little off after running almost empty on petrol, the check engine light came on, sometimes between 1,000rpm and 2,000 rpm there seems to be a loss of power now and again, if i press the accelerator harder it wakes up back to normal, there have been times it struggled to start first time, and once or twice it's idling high for a min then it'll go back to normal.
I took it to a garage that said the code says it's the supercharger sensor causing the check light and the part isn't expensive, but it's located in a tough spot and they will have to remove the engine and all sorts ($$$) to replace the sensor, but i don't see how that would effect it while it's idling etc, a friend said maybe from running low on fuel the filter got blocked, so i replaced the fuel filter but it still it feels laggy.
Has anyone else had the supercharger sensor fault? and if so was the car running similar to what i mentioned? or is there anything else i can try having cleaned or replaced incase there is a blockage from running low on fuel, orrrr are these most likely 2 completely different problems? i'm kinda lost as to what steps to take.
Any advice or opinions would be great.
Old Jul 29, 2022 | 11:38 PM
Cee Jay's Avatar
WTF is a "Supercharger Sensor"???
If you were low on fuel, your fuel filter may have gotten fouled with the dirty crap from the bottom of your fuel tank.
$20 and half an hour.
Old Jul 29, 2022 | 11:55 PM
peterv8's Avatar
He has changed the fuel filter.
You need to read the whole thread before answering!
I would pour a can of injector cleaner in the fueltank and see if that helps.
Also ask the garage for the code and post it here, will be easier to help you.
Old Jul 30, 2022 | 05:30 AM
Squire's Avatar
Thank you for taking the time to read the full post i'll give it a go!
Old Jul 30, 2022 | 05:58 AM
jons's Avatar
ask a different garage for the code, and post it here.
Old Jul 31, 2022 | 12:28 AM
jahummer's Avatar
The fuel pickup is on the floor of the tank so unlikely any “gunk” would wait to get sucked up.
I believe I’ve seen this same thing happen to other members, so might do a search. But I agree on getting the proper DTC.
Old Aug 3, 2022 | 03:24 AM
JagV8's Avatar
The car likely has an IAT2. I'm doubtful it is the cause but have a hunt for codes, unset OBD monitors, and use OBD to check sensors etc for plausible (or not!) values.
Old Sep 23, 2022 | 02:24 AM
flatsix's Avatar
edit
Old Sep 23, 2022 | 02:47 AM
JonWat's Avatar
Buy yourself a cheap code reader & read the code yourself
harryxtype
Mar 3, 2018 04:14 PM
jaguarxfv8
Feb 22, 2014 11:03 AM
khriss
39
Jul 27, 2013 12:19 PM
jagmadjohn
Jun 9, 2010 06:52 PM
