Timing chain replacement 4.2L
Old Aug 7, 2021 | 05:38 AM
steve_k_xk's Avatar
Default Timing chain replacement 4.2L
After delaying the inevitable I finally parked my car up on the hoist and got to work on replacing all four chains, tensioners , guides and all associated gaskets .
Before starting I made sure I had the specific tool for locking the camshafts in position, the tool for applying tension to the exhaust cam (upper chain) and the correct bit for locking the crank in place (done through the crank position sensor opening)
With the kit I purchased a TSUBAKI timing kit although I used most of the components I had to source down another crank seal and primary guides as I wasn't happy with the fit and went OEM .
Feel free to ask any questions
Chain making contact with head - primary chain stretched apprx 3-4mm
Always use oem parts (TSUBAKI guides just didnt sit correctly on dowl)
Cams tensioned , timed and torqued correctly (120nm)
Timing cover , valve covers , thermostat and throttle all back on
All auxellory fitted , drive belt on
(PS pump a PITA to get back on)
Condensor, radiator , ps cooler , trans cooler , top lock and then only fluids left to complete job
Old Aug 7, 2021 | 04:11 PM
Sean W's Avatar
Steve - if not too much PIA, can you list parts/PN required and what the specific tool for locking the camshafts in position, the tool for applying tension to the exhaust cam (upper chain) and the correct bit for locking the crank in place (done through the crank position sensor opening) so this can become a sticky?
Old Aug 7, 2021 | 06:00 PM
steve_k_xk's Avatar
TIMING CHAIN PARTS LIST
AJ87206 SPARK PLUG SEAL x 8
KSC145624 FRONT COVER GASKET O-RING x 2
AJ812399 VALVE COVER GASKET, RIGHT SIDE x1
AJ82875 VALVE COVER GASKET, LEFT SIDE x 1
C2A1456 TIMING CHAIN GUIDE RAIL.STRAIGHT x2
C2A1497 TIMING CHAIN GUIDE RAIL, CURVED x 2
AJ82325 LOWER CHAIN PRIMARY TENSIONER x2
C2A1511 UPPER CHAIN TENSIONER, RIGHT SIDE x1
C2A1512 UPPER CHAIN TENSIONER. LEFT SIDE x1
AJ83698 FRONT CRANKSHAFT OIL SEAL x1
AJ87245 VALVE COVER CENTER WASHER SEAL x4
AJ810631 VALVE COVER WASHER SEAL x2
AJ83699 UPPER TIMING COVER GASKET x1
AJ83700 LOWERTIMING COVER GASKET x1
XR81139 O RING SEAL, FRONT CRANKSHAFT x1
AJ82289 LOWER CRANKSHAFT TIMING CHAIN, PRIMARY x2
EAZ1286 UPPER CAMSHAFT CHAIN, SECONDARY x2
NNE2622BA VARIABLE CAMSHAFT SPLIT WASHER SEAL x4
AJ82856 SEAL,VARIABLE TIMING MODULE SPROCKET x2
KSH108624 VARIABLE CAMSHAFT O-RING SEAL x2
NCA2575CA CAM COVER ISOLATOR GROMMET x20
9pc Timing Chain Tensioner Crankshaft Alignment Tool Fit Jaguar Land Range Rover
https://www.ebay.com/itm/19324102777...MAAOSw8GNd1SKt
Old Aug 7, 2021 | 09:58 PM
Sean W's Avatar
@GGG would you please add this thread to the sticky section?
Old Aug 8, 2021 | 03:46 AM
DONE - Section 5. ENGINE with 'thanks' to Steve.
https://www.jaguarforums.com/forum/x...enance-227403/
Old Aug 8, 2021 | 06:15 AM
steve_k_xk's Avatar
My pleasure thank you
Old Aug 8, 2021 | 05:16 PM
jahummer's Avatar
Surely I've missed something somewhere, but as you've the 4.2, aren't they virtually indestructible? Of course this can happen to any motor, but......
Old Aug 8, 2021 | 06:37 PM
NBCat's Avatar
I've seen failed secondary tensioners on the AJ33. It's not common, but it does happen.
rockwarrior
F-Pace (X761) / C-X17
Oct 19, 2024 04:00 AM
Octavi Banana
Apr 4, 2020 08:46 AM
Doomer
Aug 15, 2018 07:01 PM
Beep777
May 25, 2013 09:56 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
