Tire Not Monitored
Old Sep 24, 2024 | 03:42 PM
RWS1965's Avatar
Default Tire Not Monitored
Hey Folks, 2013 XKR I have 2 faults, (Tire Not Monitored, then Tire Presure System Fault). I have emptied the tire with engine off and on and re filled, Still have the errors. I have not touched the battery cables to reset yet as we know thats a pain. There is some things written on this but seems different. Also, hit cancel on the wheel with no luck. Anyone else solve this 2 fault issue?
Old Sep 24, 2024 | 06:11 PM
Cee Jay's Avatar
Have your TPMS sensors checked by a tire shop, it's free. Eleven year old sensors run out of battery power. Non-replaceable batteries on those, so you would probably need all four anyway if one was bad.
Old Sep 24, 2024 | 07:09 PM
Stuart S's Avatar
Anyone using these? Any problems? 315mHz for USA
Old Sep 24, 2024 | 07:17 PM
Cee Jay's Avatar
Those ARE the ones you SHOULD use. Those are the newer version of Seimens 53004, which were correct until superseded.
Old Sep 24, 2024 | 11:05 PM
Stuart S's Avatar
That's what I thought. Thanks.
Old Sep 25, 2024 | 03:54 AM
guy's Avatar
guy
You were thinking about the tpms sensors… at midnight??
cheers.
Old Sep 25, 2024 | 07:39 AM
Stuart S's Avatar
Inability to sleep came with the territory.
Long ago, and far away.
Old Sep 26, 2024 | 08:07 AM
RedRider48's Avatar
I'm using one of these as an interim answer until I get to further investigating the pesky TPMS problem.
At least, it offers peace of mind ... It's a standalone bluetooth TPMS monitor I found on Ama.....
Amazon Amazon
I have one in DD too....
Old Sep 26, 2024 | 08:53 AM
guy's Avatar
guy
bluetooth tpms monitor? The sensors don't speak bluetooth.
Nor is there any explanation of the frequencies monitored, at the advertisement page.
Old Sep 26, 2024 | 08:58 AM
guy's Avatar
guy
Precisely the reason I have no issue with working different time zones or being on watch in 4 or 6 hour shifts...
Old Sep 26, 2024 | 09:04 AM
guy's Avatar
guy
Getting back to @RWS1965 original post, Following the battery change, did you take the car for a spin? As per the manual, there is a relearning process for the ECM and TPMS (and TCM) that can be invoked through a proper test drive process.
Also, there are specific TPMS DTCs that should give an indication of the issue.
Cheers.
Old Sep 26, 2024 | 09:20 AM
Cee Jay's Avatar
Me, I got enough sleep... I just couldn't TALK in my sleep. Or while awake, for that matter.
Three decades past.
Old Sep 26, 2024 | 09:26 AM
DGL's Avatar
DGL
Are these good for a 2014?
Old Sep 26, 2024 | 10:43 AM
Cee Jay's Avatar
The EU and GB use 433 MHz while the Rest Of the World uses 315 MHz, so unless there is something I don't know, every ROW vehicle needs any sensor that is 315 MHz. The VDO (Siemens) sensors are the usual go-to for a lot of members of this forum.
Old Sep 26, 2024 | 11:10 AM
DGL's Avatar
DGL
The VDO ones are not listed for a 2014 in RockAuto. Com. Schrader is a good brand and they are 315 frequency. Is there a difference in the 2013 and 2014?
Old Sep 26, 2024 | 11:30 AM
Cee Jay's Avatar
Hopefully someone else will chime in, I have already spewed my entire knowledge of TPMS sensors.
Old Sep 27, 2024 | 08:01 AM
wymjym's Avatar
No answers, just more questions:
I have fought the blinking tire lights for some time.Replaced several sensors and the blinking persists.
Once I find some local with the ability, mine will will be 'deleted'.
Yesterday one tire was indicated followed by the system not monitored warning. This is a new warning for me.
Does that indicate that a tpms sensor battery is dead? or has the system just finally failed?
WJ
Old Sep 27, 2024 | 09:29 AM
clubairth1's Avatar
Community Influencer
Did you replace all 4 sensors? They have a battery life of around 7 years or so.
Old Sep 27, 2024 | 09:54 AM
wymjym's Avatar
nope, just followed the blinking lights, replacing as I saw them, to no avail.
At this point in time will turn off the system before going for 4 new ones again.
Just asking if a totally dead sensor activates the red warning @ tire monitors sensor.
btw...are you going to the texas mile in a couple of weeks?
wj
Old Sep 27, 2024 | 02:37 PM
guy's Avatar
guy
