TPMS Light
Old Feb 26, 2016 | 05:10 PM
jerome41441's Avatar
Question TPMS Light
I have a continuous TPMS Light. I've changed out all four sensors and the light is still on. Is there a way to reset the TPMS Light after you've changed all the sensors? I have a 2010 Jaguar XKR with the V-8 Supercharger engine.
Old Feb 26, 2016 | 08:26 PM
Don B's Avatar
jerome41441,
I have moved your post from the General Tech forum to the forum for the X150, which is the Jaguar factory project code for your 2010 XKR. Here you will find knowledgeable owners of similar cars who may be able to offer helpful suggestions.
Cheers,
Don
Old Feb 26, 2016 | 08:28 PM
Cee Jay's Avatar
There are literally hundreds of posts on several links in the XK/XKR (X150) forum. Do a search for TPMS and you will find a whole bunch of information.
Old Feb 26, 2016 | 09:05 PM
tberg's Avatar
What is your tire psi?
Old Feb 27, 2016 | 03:31 AM
BruceTheQuail's Avatar
What worked for me was to inflate them all to about 10psi over what they should be, drive the car for a day like that, then drop them back down again.
Old Feb 28, 2016 | 10:48 PM
33 psi front and 36 psi rear
Old Feb 29, 2016 | 12:08 AM
Right, whack them up to 43 and 46 respectively and drive the car around for a bit, the light should go off pretty quick. Then get the tyres back down to normal before your spine shatters. I left mine up for a day.
Old Feb 29, 2016 | 08:39 AM
tberg's Avatar
As Bruce said, I inflated my four tires to about 42psi and was able to reduce to about 40. Below that TPMS warning would return. 20" tires are rated to a maximum of 50psi so it's still well within limits even if the ride is a bit firm.
buzzysingh
Nov 21, 2019 10:51 PM
richzak
Feb 8, 2016 10:19 PM
cpears
Feb 3, 2016 09:24 AM
m20nuts
Jan 30, 2016 07:54 AM
moff1959
Jan 30, 2016 06:42 AM
