two questiona
Old Feb 21, 2025 | 09:11 PM
Jag First timer's Avatar
Default two questiona
1, So are the adaptive dampers active only in track mode?
2. How about the exhaust, does that become active only in track mode also//
Thanks everyone, you've been very helpful!
Old Feb 21, 2025 | 10:15 PM
Cee Jay's Avatar
I had to check your profile to find out what year and model you have because you haven't YET added a signature with that very pertinent data.
2011 XKR Coupe.
Adaptive dampers are continuous and variable, they just tighten up in certain modes.
The exhaust valves open up when over a certain RPM or when in Dynamic Mode. OR better yet All The Time when you remove fuse 19 from the block behind and between the rear seats.
It's all in the User Manual, maybe you should find one to read. They used to be in the top of the forum for X150s, but that's hit and miss lately.
Old Feb 24, 2025 | 06:52 PM
1. Done, done, and done.
2. Thanks very much for the info
3. Sig should be on there now.
dcompain
May 8, 2019 05:56 PM
Martyb
Mar 31, 2019 07:26 PM
rexus31
Jun 13, 2018 03:20 PM
dcompain
May 10, 2016 07:59 PM
Evoking
Aug 23, 2012 06:29 PM
