Undertray and Splash Shield attachment to cross member- clips, push rivets, or bolts?
Old Oct 18, 2019 | 12:04 PM
TraxtarXKR's Avatar
Default Undertray and Splash Shield attachment to cross member- clips, push rivets, or bolts?
I was recently under the car yesterday and noticed something strange about the undertray and how it attached to the body and radiator splash shield... they were attached to each other using 2x ribbed plastic clips, but hanging down and not attached to the engine support bar.
Here's the instructions from another thread post:
Here's the under tray:
C2P21918
And here's the radiator splash shield:
C2P25349
Here's the clips I found on my panels, that isn't strong enough to stick into the cross member slots
Here's a WAY TOO LONG video someone took with a similar problem:
Here's a video showing someone doing an oil change that uses a threaded fastener:
So, what's the deal? Are the push rivets my car has something from a previous owner or oil change shop? Are there supposed to be speed nuts here for threaded fasteners? Anyone do their own oil change that can comment how these plastic shields are fixed to the body?
Old Oct 18, 2019 | 02:06 PM
TexasTraveler's Avatar
I can't speak to anyone else'e car, but my car does not have those push in christmas tree's. I have 2 screws and 2 10mm nuts...
Old Oct 18, 2019 | 02:42 PM
TraxtarXKR's Avatar
What do the screws attach to? Is there a speed nut in the cross member that I'm missing?
When I was under the car yesterday I saw a slot that the push rivet would fit into (but doesn't), but it seems like a plastic retaining clip could go there as well, for a screw to thread into.
Everything points to an oil change and the OEM fasteners went missing so they used push rivets they had in the shop to finish the job and sent the PO on their way.
Old Oct 18, 2019 | 02:47 PM
jahummer's Avatar
Same
Old Oct 18, 2019 | 02:57 PM
Pause the second video @ 3:22, gives you a pretty clear shot of the snap in fastener that takes the screws... It's a metal fastener, I haven't looked close but probably a U style nut or a cage nut
Old Oct 18, 2019 | 02:58 PM
DannyJ's Avatar
That's what you were supposed to have
Old Oct 18, 2019 | 03:17 PM
TraxtarXKR's Avatar
FANTASTIC! That's what I need. Great job. Items 10 & 11
https://parts.jaguarpalmbeach.com/a/...T/4740040.html
Old Oct 19, 2019 | 05:48 AM
The body has two square holes which each have a white nylon "snap-in" nut inserted. The rear of the undertray is then secured to these using a self tapping screw and a washer through the recessed holes. This is what they look like:
I had one "snap-in" nut break on my 2007 XK and had a hard job finding a replacement - Jaguar don't list them.
Old Oct 19, 2019 | 08:59 AM
IanXF's Avatar
The spring nuts are listed under the XF parts list my dealer knew this and saved a lot of searching
Old Oct 21, 2019 | 03:17 PM
TraxtarXKR's Avatar
Those look like license plate inserts, but I would definitely prefer to go with a metal spring nut over the plastic insert, given how much road debris that part would see, I bet the plastic insert would crack in no time. They only last about a year holding license plate screws.
Old Oct 25, 2019 | 12:07 PM
gkubrak's Avatar
I am missing one of those screws. Dealer can't even get a replacement. I measured the thread and literally no screw exists with that thread.
For now I have 2 washers and standard wood screw holding it. Would like a more permanent solution.
Anyone know where to get the actual screw? Its not the 1 listed in the parts catalog for some reason.
Old Oct 25, 2019 | 03:44 PM
IanXF's Avatar
Nut-Spring - Jaguar (C2D20870)
matched bolt and washer from A hardware store
Old Oct 30, 2019 | 10:38 AM
TraxtarXKR's Avatar
My dealer sent me these:
Given the diameter of the shoulder on that screw, I think it's not the right part...
Old Oct 30, 2019 | 11:14 AM
Cee Jay's Avatar
Maybe your holes are ripped open? Throw a washer in there.
Old Oct 30, 2019 | 11:21 AM
TraxtarXKR's Avatar
If that looks correct to those that still have the OEM fasteners installed, they must be the right parts.
Yes, I was planning on just using a washer to increase the diameter of the head. Given that the parts diagram doesn't show any washer, I'm thinking those fasteners are actually for something else (like attaching #9 in the diagram below). I wish Jaguar's part diagrams and illustrations weren't such garbage. Probably the worst I've ever come across.
Old Oct 30, 2019 | 02:49 PM
IanXF's Avatar
that looks like the alternator bracket nut spring and bolt the one I showed matched perfect with the one i took out
Old Oct 30, 2019 | 02:53 PM
TraxtarXKR's Avatar
Thanks Ian. Do you know what diagram your part is shown on? I can't seem to find it anywhere.
Old Oct 30, 2019 | 05:50 PM
IanXF's Avatar
I west to Jaguar of the palm beaches. Parts guy looked it up said it was in the XF parts list not the XK I did the same thing buying the alternator nut spring first. He was only able to find it after he matched it up to the one I brought in.
Old Oct 31, 2019 | 02:34 PM
TraxtarXKR's Avatar
Sure enough... here's what my parts guy said:
That C2D20870 pops up in a couple of different places in Jaguar’s parts catalog, including in the front bumper for the XK. Oddly enough, that part number is in the catalog for the XK front bumper but isn’t actually pictured in the diagram. The best picture I could find was in the engine undertray section for an XF model. The #21 (C2P23640) looks like it would be the fastener you need for that C2D20870 nut.
Old Oct 31, 2019 | 03:04 PM
https://www.brit-car.co.uk/product.p...__xk___xf___xj
Looks right to me...
