Updating with LED rear lights?
Received 1,897 Likes
George Kale created a nice write up on how to do it.
See Post #51 in this thread:
https://www.jaguarforums.com/forum/x...s-36907/page3/
I got my lights and harness from SNG Barratt, here in the US. Resistors and relays I bought online from various sources.
You may have other sources over there.
peterv8 (07-03-2018)
Nice write up but why do I need the 2010 harness, I see the inner lamp has a different connector, 3 wires instead of 2 which is for both fog and reverse and my car has one of each but I was planning of taping in to them and connect the extra light on each side. Is the connector on the main led light the same as on the car, only need to switch places on some wires?
The resistors are 25W 25ohm, I have found 25W 8ohm over here!? What's the difference, my thoughts are that I need 25W resistors, does it matter what ohm they are?
I will be back with more questions!:-D
The wattage (W) was selected as being a safe value to absorb the power. You could use higher wattage resistors, but the packaging would be larger and harder to deal with.
peterv8 (07-11-2018)
The resistance in ohms is the key, but when I did my light conversion I had to do a lot of trial and error to get rid of the faults because the suggested resistances weren't suitable.
On mine it was an 8ohm on each of the brake lights, 12ohms on the left rear indicator, 6ohms on the right rear indicator.
You do need the harness for the inner lights because not only are the plugs different, is wired up differently as well with both reverse and fog wires to each side, the earlier lights are one only to opposite sides.
peterv8 (07-12-2018)
I bought the left rear light from a scrapyard for a good price as it had some scratches on it. Arrived yesterday and when I unpacked it the scratches were doable to "hide with a good polish but what those idiots didn't see was the crack where water and dirt had come in!:-(
They gave me a full refund but pisses me of how they "missed" something so important.
My updating plan is on ice right now as I don't have the funds to buy at "full price".
Thanks for the help so far and hope to be back on this topic soon.:-)
Peter,
What lamps do you need? All of them? I have a few GOOD used ones we're looking to move on.
Regards
William@sngbarratt.com
Regards
Peter,
Regards
Regards
Here's some prices, i realize they're bit all over the place but might save you some $$ getting the last couple of used ones we have.
C2P21459 LHR Inboard New $149.00
C2P21458#/1 RHR Inboard Used $90.77
C2P21452#/1 LHR Outboard Used $179.21
C2P21451 RHR Outboard New $282.94
C2P16337 Harness if reqd. $105
Kind Regards
William@SngBarratt.Com
Kind Regards
I wonder why these wouldn't work for brake light and turn signal, anybody tried?
Canbus decoder
Would be alot easier!:-)
Canbus decoder
Cee Jay (08-12-2018)
