Upgrading injectors where to find? 4.2sc Jaguar XKR
Old Mar 11, 2021 | 10:47 PM
AlexJag's Avatar
Sponsor
Default Upgrading injectors where to find? 4.2sc Jaguar XKR
Planning an e85 full conversion. Any info on which injectors can be used will be greatly appreciated!
07-09 XKR
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Mar 12, 2021 | 05:13 AM
guy's Avatar
guy
why?
https://www.caranddriver.com/researc...at-is-e85-gas/
Old Mar 12, 2021 | 07:25 AM
gkubrak's Avatar
Dont let CA emissions and Nancy Pelosi take you down this path!!
Old Mar 12, 2021 | 01:30 PM
AlexJag's Avatar
Sponsor
your realy asking why? It's only the most common power adder on forced induction cars these days
https://www.google.com/search?q=why+...obile&ie=UTF-8
__________________
Old Mar 12, 2021 | 01:39 PM
Cee Jay's Avatar
A lot of Mustang guys get E85 tunes and gain a LOT of power.
Old Mar 12, 2021 | 04:46 PM
V7Sport's Avatar
Very interesting! Was aware of Indy cars and speedway bikes on alcohol. Very high engine performance.
But E85 was hard on alcohol intolerant road car components except Flex fuel cars so personally never considered it. And I don't think it is available locally anyway. Please keep us posted on your higher performance pursuit.
Old Mar 12, 2021 | 07:15 PM
AlexJag's Avatar
Sponsor
Thanks, I love the persuit of power ! If you follow my threads ,I have one of the highest dyno 4.2 sc xkr cars around as well as fastest 0-60 and 1/8 mi times, also just finished tuning the fastest 5.0 XFR on the world recently , so far at 11.4 but likely it will be even lower than that soon
__________________
Old Mar 13, 2021 | 05:51 AM
XJR-99's Avatar
You can go quite far with stock injectors, but next step could be Bosch EV14 49mm 630cc @3bar., 0280158298
Old Mar 13, 2021 | 10:09 AM
AlexJag's Avatar
Sponsor
Originally Posted by XJR-99
You can go quite far with stock injectors, but nexy step could be Bosch EV14 49mm 630cc @3bar., 0280158298
Thank you! How about the capability of the stock fuel pump?
__________________
Old Mar 13, 2021 | 11:13 AM
XJR-99's Avatar
I am not very familiar with 4.2 single pomp ( returnless fuelling system), but what I know from 4.2 TS installs, the pump has some limitations and you can not control the duel pressure. I have rails from 4.2 but the have modded with return line and 2 x 255 Walbro. KB Boost-A-Pump can be used to increase pump capacity at WOT. My injectors are quite big ones... But big airpump needs a lot of fuel 😎 E85.
Old Mar 13, 2021 | 12:10 PM
AlexJag's Avatar
Sponsor
I tried testing the capability of the stock injectors and I think they are running out of room at 34% ethanol mixture. I can control the fuel pressure in the ECU but it appears they adjusts on demand per AFR requirements anyway or I'm misunderstanding on how it works. I have seen it as high as 75 psi at wide open throttle and at around 44 PSI at idle.
Old Mar 13, 2021 | 02:50 PM
XJR-99's Avatar
Idle = base pressure - vacuum
Wot = base pressure + boost
Old Mar 13, 2021 | 03:20 PM
steve_k_xk's Avatar
I've looked on dragtimes and I haven't seen your runs listed for the xfr ???
Did you not run these times at a actually drag strip
Old Mar 13, 2021 | 03:27 PM
AlexJag's Avatar
Sponsor
Expecting better results at the drag strip. Dragy was used on the back streets . If you're not familiar dragy is dead on accurate uses 10 GHz gps device for measurements simalar to Race Logic.
Old Mar 13, 2021 | 03:35 PM
AlexJag's Avatar
Sponsor
I guess I have to look into that more , but I can't be making 31psi of boost so I wonder how that works
__________________
Old Mar 13, 2021 | 06:47 PM
steve_k_xk's Avatar
so these times are technically unofficial ..a back road in the middle of no where does not make this officially the fastest xfr that can't be claimed- please get it to a drag strip (don't take this the wrong way)
Old Mar 13, 2021 | 08:47 PM
AlexJag's Avatar
Sponsor
Steve I got nothing to prove to you I can tell you this though , I go drag racing regularly And most of my buddies have Draggy devices as well and Track time slips are always nearly identical to Dragy time slips down to hundreds of a second. By the way most magazines use these sort of GPS devices for testing and not the actual track slips.
__________________
Old Mar 13, 2021 | 11:39 PM
XJR-99's Avatar
Base pressure for 4.2 is 55PSI, so you have 11PSI vacuum and 20PSI boost if those readings are right.
Old Mar 14, 2021 | 01:18 AM
MoscowLeaper's Avatar
Anyway, there was a 50shot of cheating, so thats not a "fastest" car, it's a cheating car
Old Mar 14, 2021 | 03:32 AM
AlexJag's Avatar
Sponsor
There is no way I have 20psi of boost more like 11- 12, so I wonder how that works out
__________________
