Water pump leak.
Old Oct 14, 2018 | 11:16 AM
Ebirmingham's Avatar
Default Water pump leak.
I am having trouble with find a fix for the water pump bleed off hose.
I keep leaking coolant from right here and every time I start it up a tone of white smoke comes out from around the alternator or under the water pump.
Old Oct 14, 2018 | 12:02 PM
kj07xk's Avatar
From the picture, it looks like the hose has been worn by contact with metal. So if the hose is leaking, the only fix is to replace it.
Old Oct 14, 2018 | 12:11 PM
I just replace the hose because it was cracked. It is the plastic fitting that is in the water pump for the hose to connect to. That is what's leaking, the hose is fine.
Old Oct 15, 2018 | 09:00 AM
110reef's Avatar
Should there not be a hose clamp on that hose?
Old Oct 15, 2018 | 10:54 AM
Nope supposed to just shove it in.
Old Oct 15, 2018 | 10:56 AM
This is what is in the water pump that it supposed to slide in.
Old Oct 15, 2018 | 11:43 AM
TexasTraveler's Avatar
I believe he is referring to the other side of what I assume is some kind of barbed fitting that goes inside the hose. Typically you would see a clamp of some sort on the rubber hose, but maybe not?
Old Oct 15, 2018 | 12:05 PM
This little clip sits inside of the water pump, the the little nipple on the hose slide into that pushuing the little arms out to hold it in place. While pulling out the hose the clip pulled out aswell. There is no other clip, attachment or anything.
I am wondering if this is supposed to stay in the water pump with a seal or something.
Old Oct 15, 2018 | 12:19 PM
110reef's Avatar
Did you put that clip back in?
Old Oct 15, 2018 | 12:21 PM
Obviously.... Or else I would be on these forums about it still leaking.. come now..
Old Oct 15, 2018 | 12:35 PM
110reef's Avatar
Not trying to be a smart-****. But after being an engineer for 35 years, I have learned that you always ask the obvious questions first. After all this is the internet and there are all levels of competence out there.
So to better understand your problem, let me re-cap - it seems that the connection where the hose enters the metal housing is leaking. It is not leaking on the hose to plastic connection, rather it is leaking where the fitting enters the housing. Is that correct?
Old Oct 15, 2018 | 01:44 PM
Yes I thought of that after I said that actually. I apologise for that.
Yes sir that is exactly it. Every other forum I go to they say you need to get the new design coolant hose with the new attachment but that doesn't solve the problem because its on the housing like you said. Then others say to just take it to the dealership but I much rather not pay $150 just for them to look at it then who knows how much they will charge for the part. It's also really scarey because every time I start it up white smoke comes pouring out.
Old Oct 15, 2018 | 03:59 PM
So I see the front part of the push-in quick connector. Is there a retainer clip and o-ring still inside the water pump housing? I would think like most quick connect fittings there should be an o-ring to make the seal? Check to make sure that the retainer clip is still there to hold the pipe in place and check that the o-ring is still in place and is not worn-out or damaged...
Old Oct 15, 2018 | 08:13 PM
Patrick Wong's Avatar
Do you need #5 per the attached parts catalog exploded parts diagram?
https://www.parts.com/index.cfm?fuse...0-%20Liter-GAS
Busa196
Jan 13, 2025 04:33 AM
AML
Feb 29, 2012 08:38 PM
AntixSD
Apr 3, 2010 07:40 AM
mrcjr24
Sep 16, 2008 10:02 AM
