What’s behind here?
Old Mar 15, 2025 | 06:58 AM
Bikergonebald's Avatar
Default What’s behind here?
What’s behind / inside the panel in front of the battery? Can I drill in to it?
I’m currently considering options for a subwoofer installation. It looks like thin sheet panels covering something structural.
thanks
Old Mar 15, 2025 | 09:29 AM
kj07xk's Avatar
Take out the rear seats, and you’ll see the electronics and wiring on the other side of the panel. Don’t drill blindly into panel, you may create a huge headache.
Old Mar 15, 2025 | 02:05 PM
great. Thanks for the warning!
Old Mar 16, 2025 | 05:03 AM
terryg's Avatar
thanks
A fuse/relay panel and a myriad of wires, and I support kj07xk recommendation to not drill blindly. All is visible if you remove the rear seat back.
Old Mar 16, 2025 | 01:44 PM
Stuart S's Avatar
To make things perfectly clear: if you poke around behind the rear seats, that might be the last thing you ever do.
In order to install what the factory forgot - the remote control top module with rear window controller made by WhiteXKR (Steve, the Jag Wrangler) - I had to remove the rear seats to access and remove the pop-up roll bars. I was terrified to do that, as I worried that I'd accidentally trigger the pyrotechnics that activate it.
Pop-up Roll Bars
Thanks to Steve's outstanding instructions, I survived.
Old Mar 16, 2025 | 03:21 PM
kj07xk's Avatar
Pop-up Roll Bars
From his posted picture, he has a coupe. So on the plus side, no roll bars to deal with, but on the negative side, it’s a coupe, so Steve’s controller would do him no good (unless Steve has figured out how to open the roof on a coupe ).
Old Mar 16, 2025 | 08:22 PM
Stuart S's Avatar
Good point!
Felixbobcat
24
May 16, 2024 02:27 PM
Doug
Feb 20, 2024 11:47 PM
not an engineer
Dec 18, 2022 08:31 PM
ddykstra
Aug 21, 2022 08:11 PM
Jagmk21964
24
Mar 15, 2021 07:51 AM
