What did you do to your X150 today?
Old Jun 25, 2019 | 09:50 PM
  #801
gkubrak's Avatar
Originally Posted by Reverend Sam
Which bulbs did you use? Link?
A 10 pack from amazon. If you can get shorter ones, do so. I had a tough time putting in the front inner ones and had to secure them with tape after some of the plastic housing cracked off. Woops.
link link
Originally Posted by badicedog
Mate you getting the turn signal indicator lamp failure with the LED turn signals?
I didn't replace the turn signals. Just the daytime lights. 4 front, 4 rear. If you look at the electrical diagram, the daytime lamps don't have a 3rd wire like the other lamps do. Thus there is no error signal for these. They do however stay dimly lit for a few minutes after turning off. I'll re-post if it becomes a problem in the future.
The first 2 days I drove around with no issues. Then I got the AFS warning light flashing on and off. Didn't know what it was till I looked it up in the owners manual. It went away yesterday and I haven't seen it flash again. I attribute it to the EXTREMELY frayed and chaffed wires in the headlamp units. Had to tape some of the wires up because they were so bad. Not looking forward to that in the future. Wish I had a picture of some of the wires in there. They were literally missing up to 1/2 inch of sheathing in certain spots.
Old Jun 29, 2019 | 07:26 PM
  #802
Megawatt's Avatar
Smile wing
Old Jun 29, 2019 | 07:37 PM
  #803
pwpacp's Avatar
How did you finish the boot or did you leave the stock spoiler in place?
Old Jun 29, 2019 | 08:01 PM
  #804
Megawatt's Avatar
stock spoiler with 3rd brake light still there
Old Jul 2, 2019 | 12:27 AM
  #805
tractioninc's Avatar
I restored the headlights on my car this evening. The top surfaces of the lights were yellowing and bubbling, so I used the Sylvania kit recommend elsewhere on the forum. If I did it again I’d use an electric sander because sanding by hand was a chore! The results are nice though:
Old Jul 2, 2019 | 06:50 AM
  #806
DannyJ's Avatar
Do you have a before picture?
Old Jul 2, 2019 | 10:33 PM
  #807
Ha, no. My phone was out of sight on the charger so I didn’t think of it till after I had started. The top of the lights were yellowing, with the right headlight surface starting to pit and bubble.
Old Jul 3, 2019 | 10:23 PM
  #808
tberg's Avatar
Picked up my car today where I had my front chin splitter repaired and painted after I pulled up to a concrete parking stop a few weeks ago and the rebar that holds the stop to the pavement was sticking up a couple of inches bent forward. So when I pulled in the lip of the splitter went over them without a problem, but in pulling away it locked behind the lip and tore it up pretty badly. While the car was there, I wanted to have my rotors machined as braking on the freeway was quite jittery, and finally, even though I replaced the water pump again several weeks ago as well as some coolant hoses, and so I thought my leaks were over with, I noticed some coolant loss over the last couple of weeks. This time it turned out that the oil cooler was leaking and was apparently a pain in the rear to get to including removing the supercharger. Fortunately, we still have the engine that was replaced just before I bought the car 6 years ago, and we've been using it for parts ever since. So the oil cooler was removed from the old engine and installed on my existing one, so no big parts expense. (A few weeks ago we stripped a cam positioning sensor from the old and installed in the new). So my car is back home after a week, and I've missed her, having to drive my 2002 XKR instead, the virtual jello loaf. Tomorrow, I take the Pantera out for an early morning beach and canyon run with a group of sports cars. Hopefully no breakdowns along the way.
HAPPY JULY 4TH TO EVERYONE. Make it a safe one!
Old Jul 4, 2019 | 03:57 PM
  #809
capitol1's Avatar
Toned down the chrome "XK" and the ugly key cylinder a bit.
Old Jul 5, 2019 | 04:29 AM
  #810
Stuart S's Avatar
Identity crisis? There's no doubt about what it is, considering the license plate, chrome plinth, and non-OEM Leaper. I like the less obvious key cylinder, but I'm not sure about the XK badge. My opinion doesn't matter. It's whatever floats your boat.
Old Jul 7, 2019 | 12:18 AM
  #811
Beau M's Avatar
I made a phone mount out of a mudflap. The chrome knob is from a Fender guitar and is the bass knob for my amp.
Old Jul 7, 2019 | 06:46 AM
  #812
pwpacp's Avatar
Nice inovation! Don't really need those on guitars anyway.
Old Jul 13, 2019 | 10:46 AM
  #813
Sean W's Avatar
Beau can you do a separate write up on this? Seems interesting. Not sure what the knob is for. A little more than just a mudflap too (phone resting on mounts), no?
Old Jul 13, 2019 | 10:49 AM
  #814
Sean W's Avatar
Had the exterior detailed. We all know what a shiny black XK looks like so no need for pics. Builder in my neighborhood was replacing some curbs. One was in front of my driveway. On a particularly windy day, they sprayed curing compound on the curb and of course my car was downwind.
Cost $500 to get it removed, then polished. On their dime of course.
Old Jul 14, 2019 | 10:38 PM
  #815
Beau M's Avatar
Sure, not a lot to tell. I'm using my phone as my HU, so I wanted it in an easy to access place. I started off with a piece of 3/4" wood that fits snug in the ashtray area.
There are two large holes drilled in it. One is for the phone charger to have clearance. The other is for the bass knob that runs back to the subwoofer amp.
In place. The big black piece is an old plastic mudflap. Around the edge I used plastic chrome door trim. The phone brackets came from a cheap old phone mount I got off amazon, search for IPOW anti-slip and you should find it. I was not impressed with the rest of the mount. Also, I replaced the stock bass knob with a knurled one from a Fender guitar, same ones I use in the Mustang. Nice and heavy. Unfortunately my phone doesn't support wireless charging or I would have built that into the mount, but I don't mind the cord so much.
All told this mod cost me $12 (mount from Amazon), I made it from stuff I had laying around the garage
Old Jul 15, 2019 | 07:09 AM
  #816
Sovejag13190's Avatar
Very good idea
Old Jul 15, 2019 | 11:40 AM
  #817
Stuart S's Avatar
I use my ashtray for my aftermarket backup camera display.
I calibrate it with target practice on my flowerpots.
Old Jul 15, 2019 | 11:52 AM
  #818
I've install gvif module on my 2007 xkr.
See my tuto here -> GVIF
Here my website JAGUAR XKR 2007
Marc
Old Jul 15, 2019 | 11:58 AM
  #819
Beau M's Avatar
Marc
Very cool, thanks for sharing!
Old Jul 15, 2019 | 04:58 PM
  #820
Sean W's Avatar
Marc
Here's an English version:
https://www.jaguarforums.com/forum/x...camera-179570/
