What did you do to your X150 today?
Old Oct 6, 2019 | 05:04 PM
  #941
steve_k_xk's Avatar
Q&C I'm going to see if I can round up some CCTV from the surrounding buildings and hopefully see what took place
Old Oct 6, 2019 | 09:57 PM
  #942
Don-T's Avatar
I changed my differential fluid! It took an overnight soaking in PB Blaster to break loose the fill plug and a homemade allen wrench to get it out but I did it. Somehow I thought 1.3 qts wouldn't run out but it did, so I used the fill hole as a level indicator.
Old Oct 7, 2019 | 02:32 AM
  #943
steve_k_xk's Avatar
Nice one Don by memory is the filler plug just a 3/8" drive
Old Oct 7, 2019 | 08:18 AM
  #944
TexasTraveler's Avatar
Don, if you fill to fill hole you will add 1.5L of fluid which is 200ml overfill for a XKR that calls for 1.3L... I have no idea if the extra 200ml would do any harm, but just so you know...
Old Oct 7, 2019 | 03:39 PM
  #945
Don-T's Avatar
No, the filler plug is 8mm allen wrench. I had to cut an inch off the short leg since there is only a little over an inch of clearance and then bend the long leg to clear the exhaust. I used a long allen wrench for this. The drain is a regular 3/8" plug though.
I let it drain for about an hour before putting the drain plug back in and pumped 1.3 quarts in and let it dribble back on the floor. The back end was up on ramps so maybe that effected the level.
Old Oct 7, 2019 | 04:22 PM
  #946
Yes, the information I received from a JLR tech was the car needed to be level...
Old Oct 8, 2019 | 08:30 PM
  #947
Attackgirl's Avatar
Default Paid $3K still shocked.
Just picked Candy up from Nashville Jaguar getting new water pump and hoses. I ordered the service manual and now have the electronic copy and now I’m searching for a parts place since the dealer said I also need new brakes, sensor, rotors as well as lower control arm busing all of which I will be doing myself.
Retired stress.
The feeling of driving her down the road is priceless... I guess it’s time to get a job...again,
Old Oct 8, 2019 | 08:35 PM
  #948
Attackgirl's Avatar
Do give details I definitely need one
Old Oct 8, 2019 | 08:40 PM
  #949
Attackgirl's Avatar
You replaced the whole arm verses just the bushings? Was it bent? Where did you buy your parts?
M
Old Oct 9, 2019 | 07:15 AM
  #950
barnsie's Avatar
Today I removed Fuse #19 from the fuse box behind the rear seats (2008 model year, 4.2 Supercharged XKR). This is the fuse that keeps the exhaust valves open and so makes the car sound a little sportier in normal driving. And it works - car sounds a little more muscular at normal driving speeds. Easy to reverse if I want to go back to stock.
This thread has all the details:
https://www.jaguarforums.com/forum/x...a-87400/page9/
Probably old hat to all you seasoned XKR drivers, but new for me!
EDIT:
I just did a two hour round trip in the car and it sounds fantastic. Not too loud, but noticeably more growly. The extra noise isn't at all intrusive at highway speeds but adds a lovely 'edge' at lower speeds and when accelerating from standstill. A lovely mod, and so easy to do - just two minutes, literally.
Old Oct 10, 2019 | 01:45 AM
  #951
Queen and Country's Avatar
When you go to do the job, just post your specific question and lots of people will be able to guide you.
The parts are cheap and brakes , bushings can be done by any shop.
BTW, its standard operating procedure now days for struggling shops to recommend brakes, regardless of how soon you need them. Bushings you do need, they age.
Old Oct 10, 2019 | 03:15 AM
  #952
barnsie's Avatar
This is so true, and seems especially true for Jaguar authorised service centres. In my experience, it seems that they routinely find something 'wrong' with some part of the braking system, encouraging you to have it 'fixed'. I have taken my car(s) to well-regarded Independents after refusing the work recommended and they have reported the brakes as entirely satisfactory. I guess they pick on brakes as 'needing attention' because it worries people from a safety aspect so they get the work done 'just in case', often wasting money on unnecessary work. So, as usual, caveat emptor.
Old Oct 11, 2019 | 12:09 PM
  #953
Bigbully's Avatar
EDIT:
will that affect the computer setting as to how the car rides at lower RPM?
and is it the same affect on the XK or just the XKRs?
Old Oct 11, 2019 | 01:20 PM
  #954
Ngarara's Avatar
Nope, it's just the active exhaust that is controlled by Fuse 19 - and the active exhaust is only on the XKR.
Old Oct 13, 2019 | 08:33 AM
  #955
SpinningWheels's Avatar
Default Replace or repair
I was considering the replacement of my unsightly convertible cover (some scrapes and scuffs), but the cost was off putting, to say the least. So...decided to give repairing it a go. After a light sand to reduce the visibility of the scuffs and scrapes, I painted it with trim and bumper paint.
Despite the increased glossiness, I think it looks pretty good and it was over $800 cheaper than the cheapest new option and $400 cheaper than any used.
Old Oct 13, 2019 | 09:58 AM
  #956
Stuart S's Avatar
Nicely done and looks great! And you saved lots of $$$ and didn't have to remove and reinstall that cover.
With all the masking, I presume that you used a spray can. What did you do for surface prep other than a light sanding? What grit did you use and did you use a primer? Or a matte finish clearcoat?
I suggest that you start a new thread for this topic, as it may be of interest to others. You could include more details and follow-ups to report on how it's holding up.
Old Oct 13, 2019 | 11:34 AM
  #957
pwpacp's Avatar
Very inventive DIY approach. I'd like to know all of your steps and ongoing evaluation as well.
Old Oct 13, 2019 | 11:45 AM
  #958
Attackgirl's Avatar
The Evolution upgrade sport kits?
Old Oct 13, 2019 | 11:49 AM
  #959
Attackgirl's Avatar
Boy those are clean...do share what chemicals are you using?
Old Oct 13, 2019 | 01:57 PM
  #960
George05's Avatar
Fantastic job SpinningWheels
