What did you do to your X150 today?
Old Oct 14, 2019 | 07:35 AM
  #961
SpinningWheels's Avatar
Default Prep
Originally Posted by Stuart S
Nicely done and looks great! And you saved lots of $$$ and didn't have to remove and reinstall that cover.
With all the masking, I presume that you used a spray can. What did you do for surface prep other than a light sanding? What grit did you use and did you use a primer? Or a matte finish clearcoat?
I suggest that you start a new thread for this topic, as it may be of interest to others. You could include more details and follow-ups to report on how it's holding up.
As a *** Laude graduate of Google and YouTube U, I can do any and every thing! Plus, I’m smart enough to listen to my wife who suggested this approach over removing the cover.
I sanded with an 800 grit because I was just trying to smooth the scuffs some , I used a wax and tar remover and then simply washed it and allowed it to dry. After masking, I sprayed without primer because the product (Rustoleum Trim and Bumper) said it adheres directly to the clean plastic surface.
All done, I’d say it looks really good. Carefully masking made it a breeze and the smallest overspray on the chrome was removed using my fingernail. Being the impatient guy I am, I didn’t allow adequate time between coats, so the drying will be ongoing. Because it’s more decorative than functional, nothing ever really touches it so that won’t be a problem...I hope.
Old Oct 14, 2019 | 12:16 PM
  #962
Default Remote top and rear window mod
Not today, but last week...
The installation was a breeze with the clear and concise instructions. The only problem was the cramped operating space in the rear seats, but the convenience outcome was well worth it!
Old Oct 15, 2019 | 03:45 PM
  #963
George05's Avatar
Car not been used in over a week or so. so turned over the engine let it purr for 10mins sounded good from cold no noise and took park brake off
Old Oct 15, 2019 | 04:02 PM
  #964
Bigbully's Avatar
got the windows done this wknd. actually drove for 1st time as well... and since posts without pics are worthless, here are a couple...
Old Oct 15, 2019 | 04:26 PM
  #965
Don-T's Avatar
Got the dreaded "Tire Pressure System Fault" yesterday so today I had the TPMS modules replaced at the local tire shop. It took awhile for them to realized they had to program them to replicate the old ones. After 10 minutes of driving my tire pressure alarm disappeared. Of course, my "Smart Key Battery Low: alarm came on. Damned CR2032's don't seem to last long.
Old Oct 15, 2019 | 06:47 PM
  #966
kj07xk's Avatar
Not necessary to program them to replicate the old ones, our cars relearn the new codes, so your warning would have disappeared after that drive without programming them.
Old Oct 16, 2019 | 11:52 AM
  #967
Default Chrome tips...
Started giving the neglected chrome tips a little attention. I imagine they not been cleaned properly one time. Once they’ve been ignored this long, mostly clean and somewhat shiny is the best you can really hope for I guess.
Old Oct 16, 2019 | 07:01 PM
  #968
Cee Jay's Avatar
I'm getting new rear tires tomorrow so I used up the last bit of old ones today. Dang, tire smoke sure can fill a cabin with the roof down.
Anyway, cleaned up all the wheels and threw my four new TPMS sensors in the front seat to have those installed also. Maybe those stupid dash lights will go away now? I dunno, not holding my breath.
I used Mother's Foaming Wheel & Tire Cleaner and it worked probably better than anything else I've tried so far. I will never believe that you can merely Spray-N-Rinse to get wheels clean without first a good ceramic coating, so I did some mild wiping. Took about four minutes per wheel. I love the look of Hyper Silver, even though my wheels are just a bit scuffed up on the edges.
Put some new Headlight bulbs in that I've had sitting since last year, went in quick. Since Not Night I don't know how they will do. Guess I'll have to meander tonight just to check.
Tomorrow I'll know more about both the TPMS situation with new Siemens Sensors and the new Headlights.
Old Oct 17, 2019 | 07:44 AM
  #969
yidal8's Avatar
Don't know about the XKR, but just yesterday I replaced the original CR2032 in my XJ key fob. It lasted 3 years, and was still functioning normally, but with the low-bat message.
Old Oct 17, 2019 | 08:32 AM
  #970
Stuart S's Avatar
If you want the maximum possible battery life for your Smartkey fob, replace the original 2032 battery with a 2035 battery. It's identical to the original CR2032, except for the thickness. They're both 3V and 20mm in diameter, while the CR2032 is 3.2mm thick and the CR2035 is 3.5mm thick. That additional 0.3mm of thicknesses may provide more capacity and a longer life, and make better contact with the prongs if they've been stretched or bent.
I always buy my keyfob batteries locally so I can get a genuine name brand and check the date code to be sure that I'm buying new stock. An buy 2-pack so you can keep a spare in your glove box.
https://www.ausbatteries.com/cr2032-cr2035-difference
Old Oct 17, 2019 | 03:18 PM
  #971
Bigbully's Avatar
i clean my chrome tips every time I clean and wipe the car down.then i'll apply a coat of whatever im using...wax, or shine coat etc.to keep them easy to clean. same as wheels.
Old Oct 18, 2019 | 04:18 AM
  #972
Well...the previous owner of this feline wasn’t nearly as attentive. I had to use my Dremel with a soft wire tip to break most of the crud free.
Old Oct 18, 2019 | 10:03 AM
  #973
George05's Avatar
I am looking for a volunteer to do mine lol
Old Oct 18, 2019 | 09:51 PM
  #974
TexasTraveler's Avatar
Changed my SC oil, using George05 method...
Old Oct 19, 2019 | 12:33 AM
  #975
George05's Avatar
Old Oct 19, 2019 | 06:05 PM
  #976
Default Ceramic coating
Because the weather chose to be ultra wet for the last two days, had a good friend do a paint correction and apply Gtechniq ceramic. It looks great, but I won’t know for sure until I get to take her out to really see.
Old Oct 19, 2019 | 06:12 PM
  #977
Damn it looks good, I need a friend that talented....
Old Oct 20, 2019 | 07:47 AM
  #978
vacolorito's Avatar
It's easy to do it yourself. I did mine with great results.
Old Oct 20, 2019 | 09:17 AM
  #979
You have my attention, care to give details.....
Old Oct 20, 2019 | 10:59 AM
  #980
barnsie's Avatar
Orbital machine polisher, a couple of grades of compound, plus a few hours of time. Thoroughly wash the car first of course and then claybar it to remove any imperfections and residues (you'll be surprised how much the clay bar picks up). After the machine polishing, apply a nice ceramic glaze and the car will stay much cleaner for much longer, even in bad weather. My car is Lunar Grey like yours and tends to 'look clean' even when it isn't, but a decent ceramic coat keeps it much cleaner for much longer, as dirt and dust can't stick so easily. YouTube has tons of videos on car detailing to give you some basic guidance.
The XK(R) is such a lovely shape I enjoy cleaning it more than most cars I have owned. It's like caressing the body of a beautiful woman (© Swiss Tony)
